Auto-Shutdown Circuit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokndiesel7588, this thread has received 4 replies and been viewed 1705 times.
post #1 of 5 (permalink) Old 04-19-2010, 11:40 AM Thread Starter
Singles Club #2
smokndiesel7588's Avatar
Just did a 6 spd conversion in my truck. Was having defueling issues when i had the computer on the firewall from the auto in the truck. I picked up the computer from the truck the manual came out of, and I could rev past 3k RPMs once again. I thought all was fine, but later that day, the battery gauge went all the way down, followed by the rest of my gauges. The truck ran fine still, so I ignored it .
I ran a code check and came up with the following:
P0230 Transfer Pump (Lift Pump) Circuit Out of Range
P0252 Fuel Injection Pump Valve Stuck
P1388 Auto Shutdown (ASD) Relay Control Circuit
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
If anyone has any suggestions, it would be greatly appreciated.
Greg
smokndiesel7588 is offline
post #2 of 5 (permalink) Old 04-19-2010, 02:09 PM
2nd Gen Guru
Mopar1973Man's Avatar
Did you get the VIN number flashed to it to unlock it?
Mopar1973Man is offline
post #3 of 5 (permalink) Old 04-19-2010, 04:18 PM Thread Starter
Singles Club #2
My vin flashed to the new computer, or the vin from the wrecked truck to my ECM? I sent Bob Wagner an email to get the code for reprogramming it with my Smarty, I was just under the impression that I needed to do that to use the original computers.
Greg
post #4 of 5 (permalink) Old 04-19-2010, 04:46 PM Thread Starter
Singles Club #2
Well Bob just got back to me with something to put on the smarty...guess when I get home I'll give it a try.
Greg
post #5 of 5 (permalink) Old 04-20-2010, 03:43 AM Thread Starter
Singles Club #2
just an update...loaded the software...and it works and charges the batteries with the automatic PCM. The manual one still shows lower battery voltage, but it works otherwise and I have a feeling my batteries are on their way out anyways.
Greg
BD Diesel's NEW Positive Air Shutdown P.A.S. [email protected] Diesel Supporting Vendors Forum 0 12-17-2009 11:03 PM
671 oil burp out crank vent on shutdown maklandscape Medium and Heavy Duty 7 10-21-2009 01:49 AM
Fuel shutdown solonoid? 9 Lives Diesel Conversion 5 10-30-2007 04:25 AM
30 Second Injector Flush on Shutdown JSxFX4 2003-2007 6.0L Power Stroke 24 11-20-2006 06:24 PM
2004, w/30K miles backfire? when shutdown john0973 5.9L Cummins (2003-2007.5) 8 06-14-2006 01:09 PM
