Rear Axle Hub Nut? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by scott 1, this thread has received 8 replies and been viewed 14880 times.
post #1 of 9 (permalink) Old 04-19-2010, 08:11 PM Thread Starter
Rear Axle Hub Nut?
Hey!
Does anyone have the size of the rear axle hub nut on a 98 Dodge 2500 4x4 Cummins. Chiltons manual doesn't give size and there R&R sucks.
Thanks
scott 1 is offline
post #2 of 9 (permalink) Old 04-20-2010, 03:37 AM
Singles Club #2
smokndiesel7588's Avatar
i believe its a 2 9/16"...i bought the tool from a NAPA store...they go for like $25
Greg
smokndiesel7588 is offline
post #3 of 9 (permalink) Old 04-20-2010, 02:25 PM Thread Starter
Thanks Greg!
scott 1 is offline
post #4 of 9 (permalink) Old 04-22-2010, 05:42 AM
IDImonsterstack's Avatar
damn thats a big nut!
under the knife for rebuild
IDImonsterstack is offline
post #5 of 9 (permalink) Old 04-22-2010, 04:25 PM
Singles Club #2
yea, and unfortunately when I went to disassemble everything, I didn't know that the shop where I was going to pull it apart didn't have that socket. So the guy helpin me pulled out an air hammer to get the nut off That chewed up the edges of the nut a lil bit. We found out later that some people take a chisel/prybar and jam it between the nut and the hub, then spin the hub counterclockwise to loosen the nut (and put it on the opposite way of course).
Greg
The Following User Says Thank You to smokndiesel7588 For this addition to TDG:
scott 1 (04-23-2010)
post #6 of 9 (permalink) Old 04-23-2010, 01:20 AM Thread Starter
How About another test?
Thanks and you were on the money with the 2 9/16 ! What about the torque procedure back on. The book says 120 to 140 ft pounds but there is no way that can be that tight! They must be backed off the proper run load to what? Do ya know ?
Jeff
scott 1 is offline
post #7 of 9 (permalink) Old 04-26-2010, 01:12 PM
Singles Club #2
I actually didnt use a torque spec when i did mine. I tightened the nut until I could not spin the hub, (this made sure that all the bearings were properly seated, as well as all of the seals. I then slowly loosened the nut until the hub spun freely like the other side.
Hope this helps
Greg
post #8 of 9 (permalink) Old 04-26-2010, 02:42 PM
2nd Gen Guru
Mopar1973Man's Avatar
When I was rebuilding 2 1/2 ton military axles we would run the nut down tight then back off the distance of one flat of the nut. Then set the locks and jam nut...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
scott 1 (04-29-2010)
post #9 of 9 (permalink) Old 04-29-2010, 10:39 PM Thread Starter
Thanks to Micheal and Greg! I Fianally found a Mitchels book that gave the procedure, but either of yours probably would have worked. There instructions were torque to 120 to 140 spining hub, then back off 1/4 of a turn.
So now we all know for future use!
Sorry I didn't respond sooner, but I've been working alot!
Jeff
scott 1 is offline
rear axle 1995nicholas 1994-2003 7.3L Power Stroke 3 03-09-2009 05:30 AM
10.25 rear axle chevyforlife502 Whats Been Sold 0 01-30-2009 10:25 PM
New HD rear axles and rear axle parts TonyBurkhard Whats Been Sold 6 11-08-2007 02:17 AM
04-16-4 Rear Axle Popping/chatter Noise - Dana 80 Model Dual Rear Wheel (drw) Squatch Ford Oasis requests 0 03-23-2007 11:56 AM
Lost stud & nut from rear hub on rear axle Duke Medium and Heavy Duty 4 09-18-2005 06:31 AM
