bad oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bcmueller, this thread has received 5 replies and been viewed 8042 times.
post #1 of 6 (permalink) Old 04-19-2010, 08:50 PM Thread Starter
Cummins POWER
bcmueller's Avatar
bad oil leak
my truck like many others on here latley has had a really bad oil leak the whole drivers side of the engine is covred in oil this has just really got bad in the past week. i drive it 30-40 miles a day and im putting in a quart of oil every 2 days latley. i would assume that this is the vaccum pump seal but that just seems like alot of oil im going through to me? any imput is greatley appricated.
2002 Ram2500, auto, silencer ring, BHAF, ATS arc flow, 2'' top gunz leveling kit, 305/70/16 Firestone Destaion A/T's on Weld Evo's, straight piped, 2-stroke
bcmueller is offline
post #2 of 6 (permalink) Old 04-20-2010, 03:39 AM
Singles Club #2
smokndiesel7588's Avatar
have you checked the bolts on the front cover? i've seen them come loose a couple times before and leak oil all over the place...just a thought
Greg
smokndiesel7588 is offline
post #3 of 6 (permalink) Old 04-26-2010, 02:44 PM
2nd Gen Guru
Mopar1973Man's Avatar
Front crank seal, vacuum pump, stock crankcase vent with excessive blowby... Just a few...
Mopar1973Man is offline
post #4 of 6 (permalink) Old 04-27-2010, 09:05 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Get some degreaser, soak it for about 15-20mins and rinse off then start it up and just get under it and watch it for.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 6 (permalink) Old 04-29-2010, 06:58 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
good chance its the front case gasket and or cover gasket........not a fun project at all half the damn truck and engine gota come apart
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #6 of 6 (permalink) Old 04-30-2010, 02:41 AM
Couldnt be bad as mine. i sold my truck and i told the person, it would be a good idea to put valve cover breathers in it so the tappet cover wont bust again. Make a long story short i took the truck back and got in it and started and seen no oil pressure and quickly turned it off and open the hood and checked the oil level and there was probably a quart in it, and seen this big ol puddle of oil and Man i was cussing like a sailor and they acted like it was a deal. So now im in the process of replacing the tappet cover,gear housing gasket,vaccum pump seal,valve cover gaskets bascally the whole nine yards!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
oil leak MoBe88 2003-2007 6.0L Power Stroke 6 07-20-2009 11:36 AM
leak strokethisfordboy09 5.9L Cummins (2003-2007.5) 0 07-12-2009 11:17 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
Oil Leak in X. cdiesel 1994-2003 7.3L Power Stroke 15 01-03-2007 10:03 PM
oil leak 05dury 5.9L Cummins 12 Valve (1994-1998.5) 8 08-04-2006 02:35 PM
