I need some brainstorming on a problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by raven, this thread has received 4 replies and been viewed 774 times.
post #1 of 5 (permalink) Old 05-04-2010, 02:52 AM Thread Starter
I have a 1999 dodge it has quadzill adrenaline, and fass fuel pump. The valve body is high pressure and it has a georand torque convertor. My problem is that my torque convertor is jumping in and out. This only happens when I am driving at a steady speed down the highway. It doesnt happen when I am accelerating or when i have my manual lock in switch on. the trans temp is always under 150 as well. When i changed my oil last week i disconnected the batteries and when I hooked everything back up everything worked fine for a two weeks. Today it started jumping again so I just used my manual switch on the way home tonight. I have a hard time believing that it is shot if it "fixed itself" for two weeks. Please just throw out any ideas that you might think of.......please help me haha thank you.......................bob
1999 2500 24v cummins..... built vp44 with fass fuel system with oversized lines, quadzilla adrenaline, built auto and convertor, 5 inch to 6 inch stacks, intake.
1994 dodge 12v cummins...(my project truck) Built auto with shift kit, afe intake, marine 370s,#0 plate, afc forward.
raven is offline
post #2 of 5 (permalink) Old 05-04-2010, 03:24 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Im thinking the electrical maybe. Did you tune the TPS?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 5 (permalink) Old 05-04-2010, 08:54 PM Thread Starter
I just bought this truck two months ago and i have not done any thing to this truck myself, so what are you thinking that i should do??
raven is offline
post #4 of 5 (permalink) Old 05-05-2010, 04:52 AM
Here is a kit to fix it
http://www.dnrcustoms.com/newproducts/overdrivekit.html
Here is how you tune it:
http://dodgeram.org/tech/transmissio...TPS_adjust.htm
But what i would do is call goerend first, to make sure im not telling you anything wrong and goerend number is (563)-778-2719
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #5 of 5 (permalink) Old 05-05-2010, 03:55 PM
2nd Gen Guru
Mopar1973Man's Avatar
Timbo Apps might be a better choice than hacking up the wiring and adding on a bunch of stuff...
Typically the problem is the carbon track wears out making it very unstable for the voltage hence lock and unlock the TQ conv. I found if you replace with a Timbo the problem is over...
No crazy voltage calibrations to do... It just works...
I look at it this way the truck work all these years without the hack and modification why do it need it now? It don't the fact is something is wore out and needs to be replaced... Don't cover up a problem with a hack or wiring mod...
Mopar1973Man is offline
Is this an ICP problem? imported_LiftedBlackHD 2003-2007 6.0L Power Stroke 18 06-26-2007 01:41 PM
1 new problem, 1 old problem, 1 problem fixed LOL Liftedpsd 2003-2007 6.0L Power Stroke 16 04-23-2007 12:13 PM
Git another problem Andy 1994-2003 7.3L Power Stroke 8 03-10-2007 07:10 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
'95 F-250 problem legacy76 1994-2003 7.3L Power Stroke 2 07-02-2006 11:49 PM
