1998 dodge 2500 with cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodge Cummings, this thread has received 11 replies and been viewed 2822 times.
post #1 of 12 (permalink) Old 05-05-2010, 03:32 AM Thread Starter
Looking for some suggestions. I had the fuel pump go on my cummings and installed a new one. I had a hell of a time getting it started but finally did but it is running really rough. I have checked all injectors and they are receiving fuel. The truck idols very rough and when I depress the gas pedal it doesn't do much at all. The check engine light is on and stay's on. I had a battery charger hooked up because of all the starting issues and it seems to idol a lot better with the charger hooked up. I am going to test the batteries tomorrow but don't know if that would effect the rough running. Does anyone have any suggestions? Thanks
Dodge Cummings is offline
post #2 of 12 (permalink) Old 05-05-2010, 04:36 AM
did you bleed ALL the air out of the fuel lines?
99' Dually is offline
post #3 of 12 (permalink) Old 05-05-2010, 11:24 AM Thread Starter
Yes, at the injector pump and at all injectors.
post #4 of 12 (permalink) Old 05-05-2010, 02:16 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Did you hook up everyting such as electrical and so forth, the reason i was asking because i forgot to plug in my throttle response and it was like that
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 12 (permalink) Old 05-05-2010, 02:28 PM
You can also go to your local advance auto parts or autozone and get them to check the code for you and its free!!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #6 of 12 (permalink) Old 05-05-2010, 03:47 PM
2nd Gen Guru
Mopar1973Man's Avatar
Need to know what the error codes are...
http://mopar.mopar1973man.com/cummin...rror-codes.htm
Mopar1973Man is offline
post #7 of 12 (permalink) Old 05-05-2010, 04:34 PM Thread Starter
error codes are P1688 internal Inj pump failure- P0253 Inj pump fuel valve open circute -Those were both showing and then first one wasn't there once checked it again. Everything is plugged in and hooked up.
post #8 of 12 (permalink) Old 05-05-2010, 06:01 PM
2nd Gen Guru
Injection pump is dead... (Sorry!)
post #9 of 12 (permalink) Old 05-06-2010, 03:26 AM Thread Starter
even if I get fuel pumping on back four injectors? the front two come and go! and if it is the injector pump to you have any idea of what is costs for a reman or place who may rebuild them? I would not like to spend to much on it because all though the truck is still in good shape and has 2000,000 miles on it's hard to dump a lot of money in it..And thanks to everyone helping with my problem.
post #10 of 12 (permalink) Old 05-06-2010, 03:29 AM
2nd Gen Guru
VP44 cost about $1,100 to $1,200 (Remanufactured)
rear end 1998 dodge 2500 dana 70 3.54 gears ash_flat_diesel Dodge Parts 0 08-30-2009 03:09 PM
1998 dodge cummins 2500 ext cab 4x4 cumminslow Whats Been Sold 4 03-25-2009 04:35 PM
1998 Dodge 1 ton 4x4 lifted cummins $12,500 FIRM W/PLOW RookieMT Whats Been Sold 11 02-22-2009 03:35 PM
99 dodge cummins 2500 Jamison Whats Been Sold 3 07-06-2007 05:59 PM
1998.5 Dodge Ram 2500 QC 4x4 ewatts2003 Whats Been Sold 1 05-27-2007 04:53 AM
