Edge Fuel Pressure Alarm - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Brand-Xrugger, this thread has received 2 replies and been viewed 599 times.
post #1 of 3 (permalink) Old 05-09-2010, 04:07 PM Thread Starter
My Edge fuel pressure alarm went off while driving yesterday. The strange thing is I am only connected to the injection pump with the posi tap. I never hooked it up at the peacock valve. Does anyone know if this reading is true at all and should I be worried? The alarm has never gone of before. Any help would be great.
Thanks
B
Brand-Xrugger is offline
post #2 of 3 (permalink) Old 05-11-2010, 12:16 AM
if you never hooked up the gauge sending unit then it's not working.
01quadcab is offline
post #3 of 3 (permalink) Old 05-14-2010, 11:59 PM
2nd Gen Guru
Mopar1973Man's Avatar
Huh? If you never hooked up the fuel pressure sender??? (Scratchin head)
Or is it that the sender is hooked up but not with a needle valve and the fuel alarm went off now??? If it is this then I'm going to say your sender has taken on water hammer damage and will need to be replaced...
Mopar1973Man is offline
Monitoring fuel pressure with Edge? R33615 2003-2007 6.0L Power Stroke 4 03-25-2010 08:36 PM
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Viper Alarm System... Alarm keeps going off for no reason HELP! 2008TTCC General Ford Truck and Excursion 10 01-08-2009 05:00 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Edge/Fuel Pressure drummerboydw 5.9L Cummins (1998.5-2002) 17 11-26-2006 11:02 AM
