VP 44 - Loping at Idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 2 replies and been viewed 1006 times.
post #1 of 3 (permalink) Old 05-13-2010, 03:09 AM Thread Starter
JLWelding's Avatar
Thanks to Mopar1973Man I have my truck on You Tube. If some of you would be so kind as to try to diagnos my problem I would appreciate it. I am fighting rebuild shop. This is the second pump in a row, The first pump ran fine for the first 5 months then started dieing. It died at leased 100 times in 20 miles, so they sent another one. This one sruges up and down when trying to pull foward or back up. Gets real bad after eng. gets to normal temp. I have replaced everything under the hood trying to fix the first one. Here's a link:
Thank You
JLWelding is offline
post #2 of 3 (permalink) Old 05-14-2010, 11:56 PM
2nd Gen Guru
Mopar1973Man's Avatar
I see you managed to get the video out and going...
Mopar1973Man is offline
post #3 of 3 (permalink) Old 05-15-2010, 01:43 AM Thread Starter
JLWelding's Avatar
Yea I finally talked to a guy that had more trouble than I have had. He went through 7 vps. He gave some pretty good info. Says take a rubber mat place it between eng. block and vp to keep heat temp. down a little. Says he learned that from a dozer machinc. Throw the card borard that is screwed to the block away and if you wash your eng. very often it's more than likely gone anyway. I got a kick out of what the old dozer machinc said, best thing is get you some asbestos and never worry about it again. ha ha ha ha
Well the good news is they are sending another one, about time.
Loping when stopped Notplayn 2008-2010 6.4L Power Stroke 8 01-05-2010 03:44 AM
Truck is loping 6.0turbodiesel03 2003-2007 6.0L Power Stroke 21 09-30-2009 02:08 AM
Loping blackcloudCTD95 Chevy - Modification instructions, Product installs and Tech Articles 8 03-04-2009 12:42 AM
low and loping idle dieslpower97 1994-2003 7.3L Power Stroke 8 09-24-2007 11:46 PM
97 Obs Bad Loping? strokedout_07 1994-2003 7.3L Power Stroke 1 03-16-2007 01:03 AM
