Air Dog II speratic FP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99' Dually, this thread has received 3 replies and been viewed 826 times.
post #1 of 4 (permalink) Old 05-13-2010, 03:33 AM Thread Starter
Question for you guys, i installed the ADII bout 6 months ago an now im havin a lil trouble with my fp bouncin around from normal (15 psi) to anywhere up to 32 psi at anytime throttle is depressed when driving, runs fine at idle tho. never drops below 11 but just a pain and when cruisin steady at ant speed it will jump around still. called the pure flow tech, said to loosen regulator and run it in and out a few time, that didnt do a thing, havent replaced filters since install, sorry for the novel any suggestions will be appreciated. thanks guys
99' Dually is offline
post #2 of 4 (permalink) Old 05-13-2010, 11:25 AM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
try a different gauge with a different sender to be sure its the pump and not a sending unit or gauge
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
The Following User Says Thank You to MILKINGCOWBOY For this addition to TDG:
Mopar1973Man (05-14-2010)
post #3 of 4 (permalink) Old 05-14-2010, 11:55 PM
2nd Gen Guru
Mopar1973Man's Avatar
When you do replace a sender or a mechanical gauge make sure you install a needle valve or a snubber before the sender or gauge to protect it from water hammer damage which is most likely the problem here...
Mechanical gauge are in the long run more durable compared to electric gauge that tend to wig out without notice... Plus theelectric sender are expensive to replace all the time...
Mopar1973Man is offline
post #4 of 4 (permalink) Old 05-16-2010, 01:38 AM Thread Starter
im reading off my attitude moniter now, granted those arent always accurate.
