apps noise isolator - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southernman, this thread has received 2 replies and been viewed 5221 times.
post #1 of 3 (permalink) Old 05-16-2010, 12:03 AM Thread Starter
apps noise isolator
anybody know what this does, is it worth the 20 bucks i spent. or will notice any difference?
southernman is offline
post #2 of 3 (permalink) Old 05-22-2010, 12:15 AM
2nd Gen Guru
Mopar1973Man's Avatar
Personally I look at this way... If the truck ran 10 year without a APPS noise filter then that means something failed just now and need to be addressed. Don't put a bandaid over the problem...
Common problems like bad grounds. Yes the main system ground is located behind the starter and requires removal to access it.
Bad batteries... Yes bad batteries can cause issues...
Bad alternator diodes. The AC wave form leaks into the system and the confuses the ECM/PCM for performance.
Funny isn't it that you never see people buying APPS noise filters for a manual trans truck why is that? Makes you think a moment...
Mopar1973Man is offline
post #3 of 3 (permalink) Old 07-28-2014, 03:20 AM
Look under problem solved
Like (Mopar1973Man) said I have heard a noise filter works well but I my self did not like the answer so I went to the local welding shop bought some welding cables and made up my own positive and ground cables replaced all of them and problem went away. The truck runs so much better and has no voltage drops.
RachelJeanWalker is offline
APPS? 01CUMMINS24 5.9L Cummins (1998.5-2002) 7 11-02-2009 12:24 PM
Fuel pressure gauge isolator? D_B Dodge Performance Forum 8 10-02-2009 05:50 PM
apps southernman 5.9L Cummins (1998.5-2002) 2 05-29-2009 05:08 PM
do you think i can run a boost for a f/p w/ an isolator skinz0021 5.9L Cummins (1998.5-2002) 4 04-17-2006 09:59 PM
Apps haz-mat19 Dodge Performance Forum 2 02-12-2006 01:03 PM
