upgrade help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by springer, this thread has received 3 replies and been viewed 993 times.
post #1 of 4 (permalink) Old 05-19-2010, 02:41 AM Thread Starter
upgrade help
I have an 01 2500 5 speed cummins truck. I currently have edge/w monitor, Bully dog stage 3 injectors,Cold air intake, 5inch all the way back w/o muffler, Fass 150 and clutch. I have had it this way for a while and I'm looking to do something else to it, but dont know where to go from here. Should I go with a new turbo should they be twins? Should I buy a twins kit or build a twins set up? What about water/meth, any good? I use it as a daily driver alot. I also pull a K5 blazer to the woods alot for offroading. Would like to be over 500 HP. So what do you think I should do next.
01 cummins quad cab sport,Edge Juice with Attitude with Hot, 100hp injectors, 5'' exhaust turbo back, K&N intake, Fass 150, 5 speed with Luk performance gold clutch
springer is offline
post #2 of 4 (permalink) Old 05-19-2010, 02:52 AM
You will want twins and sticks to get to 500hp. It is doable with 100's, but its a lot of work. Generally, 100's with a turbo set up will get you to roughly 470ish.
post #3 of 4 (permalink) Old 05-20-2010, 12:47 AM Thread Starter
sstockton did you build your twins or did you buy a kit? I'm Pretty sure you put them together yourself. What turbos did you use? Are there any kits out there that are any good? What kind of power are you making? Whats your take on a hotrod vp44 pump I see that some people claim 100 hp but then some claim 50hp. Whats your thoughts on water/meth, any good? I was at a truck show this weekend in Lima Ohio and talked to a few people that had it and one guy says he loves it and the other says he didnt notice any difference in power just EGT's. Is this cause one set it up right and the other didn't.
springer is offline
post #4 of 4 (permalink) Old 05-22-2010, 01:26 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
From what ive heard, its totally worth it! Make a difference in EGT's, horsepower and fuel milage
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
upgrade from h2e Orangepstroke 1994-2003 7.3L Power Stroke 9 03-03-2009 03:20 AM
first upgrade???? topflight250 1994-2003 7.3L Power Stroke 13 01-09-2009 10:56 PM
maybe upgrade the outside? Bcarriveau General Ford Truck and Excursion 4 11-04-2007 03:53 PM
Next best upgrade? 6L strokin 2003-2007 6.0L Power Stroke 7 01-22-2007 03:56 PM
