white smoke on warm start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 15 replies and been viewed 4427 times.
post #1 of 16 (permalink) Old 05-24-2010, 04:56 AM Thread Starter
IDImonsterstack's Avatar
i got some issues that just popped up out of nowhere. when ever i start my truck when its warm it will shake and lope and shoot white smoke for about a min then goes away but notice the exhaust tone still has a little lope. i replaced all my filters and my FP is good at 18psi anyone know anything?? oh and about 1200rpms it sounds like it has a knock but no blown headgasket or water in oil or metal shaving in oil nothing??
under the knife for rebuild
IDImonsterstack is offline
post #2 of 16 (permalink) Old 05-24-2010, 11:50 AM
Maybe a stuck valve in the pump?? I am kinda guess here.....does it lope at 1200 while driving?
1999 2500 24v cummins..... built vp44 with fass fuel system with oversized lines, quadzilla adrenaline, built auto and convertor, 5 inch to 6 inch stacks, intake.
1994 dodge 12v cummins...(my project truck) Built auto with shift kit, afe intake, marine 370s,#0 plate, afc forward.
raven is offline
post #3 of 16 (permalink) Old 05-24-2010, 10:39 PM Thread Starter
only when i start it it will lope and blow white smoke and stutter and when i put it in drive it till surge and lope and smoke but when i get on it its like it clears out and runs fine but when i shut it off and wiat about 5 mins and start it up it will lope and blow white smoke and will do it everytime. i ran a scanner on it and the code P1291 came up as computer controlled air and fuel metering and have no clue what that is doing.
post #4 of 16 (permalink) Old 05-25-2010, 04:09 PM
turbo8781's Avatar
almost sounds like its sucking air back into the system when you shut it off
turbo8781 is offline
post #5 of 16 (permalink) Old 05-25-2010, 08:51 PM
SmokeCloud's Avatar
Have you checked your injectors?
Real Trucks Burn Diesel!
SmokeCloud is offline
post #6 of 16 (permalink) Old 05-26-2010, 04:45 AM Thread Starter
is wierd today i parked on a hill and the front of the truck uphill and it set for about 30 mins and started it up and ran fine but as soon as i parked it on flat ground and it sat for 30 mins it acted the same way it was before. i had the injectors checked todya and replaced all seals and o rings nothing wrong with them. but i found it weird when i parked it up hill i had no problems at all
post #7 of 16 (permalink) Old 05-30-2010, 02:02 AM Thread Starter
found the issue today had about 7 gallons of water in my tank from shell when i filled up
post #8 of 16 (permalink) Old 05-30-2010, 07:14 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Diffently not good!!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #9 of 16 (permalink) Old 05-31-2010, 09:02 AM Thread Starter
yeah tell me about it i was pissed i went down there and brought it to them and they were like ummmm............... we cant do anything it came to us like that . i work in a refinery so i know it did but yeah i went to shell oil ref. which is bout 2 miles from mine and yeah had it out with them lmao
post #10 of 16 (permalink) Old 05-31-2010, 07:01 PM
Did they give you some fuel back? since it was water.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
white smoke start up ldwzlaw 1994-2003 7.3L Power Stroke 17 03-08-2008 03:44 AM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
Hard to start / white smoke at start, again. bsigg 6.5L Diesel Engine 2 11-27-2007 03:57 PM
White Smoke on Start Up fuzzys69 2003-2007 6.0L Power Stroke 2 03-08-2007 01:51 AM
white smoke on cold start ? youngPSD 1994-2003 7.3L Power Stroke 29 03-02-2007 10:00 PM
