Injector Advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99' Dually, this thread has received 19 replies and been viewed 1960 times.
post #1 of 20 (permalink) Old 05-25-2010, 05:29 AM Thread Starter
Injector Advice
I'm lookin at some DDP 100 or 125hp sticks to put in the truck on my sig, its a daily driver but definitely could use more power, would the 125s be too much for stock turbo?
99' Dually is offline
post #2 of 20 (permalink) Old 05-25-2010, 06:07 AM
IDImonsterstack's Avatar
yes they will be i have 100hp sticks and the turbo get really hot just getting on hte freeway and towing i have to be very light on the pedal. 125's would make it really bad. i would go with some 50's or 75's with a stock turbo
under the knife for rebuild
IDImonsterstack is offline
post #3 of 20 (permalink) Old 05-25-2010, 11:34 AM
Singles Club #2
smokndiesel7588's Avatar
I'm running the DDP 110HP injectors along with a smarty and stock turbo. If I get in it hard it can get hot, but under normal daily driving its fine. You do have an Edge on there which will make it run hotter (since it gives more fuel).
And right now with the setup I have, my lie-o-meter is sitting at 26.6mpg..which turns out to be around 21 / 22 MPG. So they are fairly efficient as long as you control your right foot.
Greg
smokndiesel7588 is offline
post #4 of 20 (permalink) Old 05-27-2010, 02:59 AM Thread Starter
Right on guys thanks for the input, any brand recommendations?
post #5 of 20 (permalink) Old 05-27-2010, 06:01 AM Thread Starter
For the heat issue I'm lookin at gettin the snow stage 2 water/meth set up, but don't know much about that product so if someone has it, fill me in
post #6 of 20 (permalink) Old 05-27-2010, 10:55 AM
Singles Club #2
DDP and Mach injectors seem to be the most highly recommended. I cant say i have any complaints about my DDPs and I have around 30K-35k miles on them.
Greg
post #7 of 20 (permalink) Old 05-27-2010, 03:57 PM
I would go with some 75's unless your planning on upgrading the turbo later. If your into driving by pyrometer then you can manage but it gets old.
01quadcab is offline
post #8 of 20 (permalink) Old 05-28-2010, 09:49 AM
i have BD pulse injectors i love them gained about 3mpg. but yea the eyesw glued on hte EGTs get very very old im just waiting for the turbo to explode so i can put my new one on im just seeing how much it can hold lol so far 40psi and 1600F a few times.
post #9 of 20 (permalink) Old 05-28-2010, 04:30 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
Carefull the heads or gaskets dont "pop" before your turbo
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #10 of 20 (permalink) Old 05-28-2010, 07:57 PM
my brother has a 2001 cummins with 150s and does fine pullin a trailer
2001cummins is offline
can u re-o ring an injector without replacing injector? bigswede Medium and Heavy Duty 1 06-15-2009 02:01 AM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
Injector/injector tip specs? Moulder 1994-2003 7.3L Power Stroke 2 01-21-2009 04:35 AM
SOS need injector advice AUSSIEDAVE 1994-2003 7.3L Power Stroke 4 11-12-2007 12:11 PM
need some advice yellowbeast 2003-2007 6.0L Power Stroke 4 03-12-2007 06:56 PM
