vp to P - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 2 replies and been viewed 805 times.
post #1 of 3 (permalink) Old 05-25-2010, 09:13 PM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
vp to P
Buddy called ne. He did it but the truck will not register oil pressure but the motors got all sorts of it. Figuring since the pcm isn't seeing oil pressure it won't kick on fuel pjump either..
Says truck has a few codes about the vp since its no longer there..
Any help apreiciated.. any how to threads or people to talk to would be awsome!
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 3 (permalink) Old 05-30-2010, 06:58 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
He could've unplugged and forgot to reconnect the wire to the oil pressure unit. But the sender is under the injection pump and right beside the powersteering pump (kinda hard to get too). If its plugged in, you can also hook a mechanical oil pressure gauge to it. Above the oil filter, theres like a small bolt like a 1/2'' or 9/16'' and plug in the mechanical gauge and see what she reads.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 3 (permalink) Old 06-06-2010, 01:40 PM
2nd Gen Guru
Mopar1973Man's Avatar
Lift pump is completely ECM controlled no other outside sensor or relays...
I would double check the wiring between the ECM and the Lift pump plug.
Mopar1973Man is offline
