help, my 24 valve is a conspiracy theory. doing a wierd thing. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by davidfast1, this thread has received 8 replies and been viewed 982 times.
post #1 of 9 (permalink) Old 05-27-2010, 02:50 AM Thread Starter
here we go, i have a 99 24 valve short box. Bought it, then found out it had a 6'' crack in the block. I had the motor taken out and was professionally welded with a 2 year warranty and was put back together. rig has 59K original miles.
This is what its doing, it "eats" or "hides" coolant. When i got the truck back the radiator was full but the resevior to the left was empty. There are no leaks any where what so ever...none none none. Not leaking anywhere.
Its not mixing with the motor, getting in crackcase or nothing. And cools and is steady at 180-190 degrees, all day long no problems.
And the coolant was not flushed into the radiator, it was dry when put back together and coolant was just pored into the radiator.
When you get on it pretty good you can hear the air bubbles in the system.
But my questions is, is why do i have to fill up the resevior after a good days use??? and where is it going if its not leaking or mixing anywhere or with anything? the guy who put it back together said he put 2 gallons in radiator, and since i have probably put another 2 in it my self.
any thoughts????
thankyou very much!!
davidfast1 is offline
post #2 of 9 (permalink) Old 05-27-2010, 03:27 AM
Its burning it. cracked head,cracked block, bad head gasket. More than likly its only leaking under pressure
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #3 of 9 (permalink) Old 05-27-2010, 03:35 AM Thread Starter
its not blowing any kind of wierd smoke, and performs fine tho.
it had a cracked block at 57K miles but i had it fixed.
i took it to a performance diesel place, and he said its just air thats being trapped that is slowly getting out and when it gets out its being replaced with coolant in the resevior.
but idk what else could it be....im kinda freaking out.
how would i know if it was a head gasket or something like that? are those a big deal?
post #4 of 9 (permalink) Old 05-27-2010, 05:52 AM
From what I understand, greyish colored smoke comin out and you'll be able to smell the sweet scent of coolant, and see it drippin out I could be wrong
99' Dually is offline
post #5 of 9 (permalink) Old 05-27-2010, 12:51 PM Thread Starter
no grey smoke, and the only smell i smell is the diesel gas being burnt.
post #6 of 9 (permalink) Old 05-30-2010, 07:07 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
From what i've heard, if theres bubbles in the radiator while the truck is running. Its a headgasket
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #7 of 9 (permalink) Old 06-03-2010, 04:31 PM
BigRed Cummins's Avatar
your truck holds more than 2 gallons. Mine took 4, so your right there now. I would see if it ever stops. was it cracked in the typical spot for a 53 block? Or where?
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #8 of 9 (permalink) Old 06-06-2010, 01:52 PM
2nd Gen Guru
Mopar1973Man's Avatar
Total capacity of the cooling system is 6 gallons...
Typically I pull the heater hose off the back to fill it so the air can escape from the block. Once coolant starts to dribble put the hose back on. Typically in 1-2 days the system will purge the rest of the air from the cooling system...
Mopar1973Man is offline
post #9 of 9 (permalink) Old 06-09-2010, 04:32 AM Thread Starter
im guessing its a head gasket or something like that cause its just wont stop eating it.
and yeah it cracked in the typical place for the 53.
The Theory of Intelligence Rcannon The Parking Lot 2 04-30-2010 04:14 PM
in theory can you???? sexytrkr 5.9L Cummins (2003-2007.5) 19 05-31-2007 11:46 AM
Stupid 9/11 Conspiracy Theories Ramprat The Parking Lot 1 09-15-2006 01:05 AM
WTC Coincidence or Conspiracy fordt The Parking Lot 8 02-19-2006 11:08 PM
Question in theory 4wydnr 1994-2003 7.3L Power Stroke 8 01-10-2006 12:11 AM
