Thinking I might have a leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Carbur8tr, this thread has received 9 replies and been viewed 926 times.
post #1 of 10 (permalink) Old 06-02-2010, 06:55 PM Thread Starter
I dont know what it is maybe just weather or something but I cant seem to get over 25 psi of boost. The only thing I can think of is that maybe i have a boot that is leaking but I really cant tell. Any Ideas?
Carbur8tr is offline
post #2 of 10 (permalink) Old 06-04-2010, 03:47 PM
start by checking the boots for leaks. I use a piece of 4" pvc with a series of plugs and reducers, to get it down to a 1/2" threaded fitting that I have connected to a valve and then I have an air fitting on it. This way I can use shop air to pressurize the system and can check for boost leaks. I have also seen people use a PVC cap, and drill a small hole in it, then caulk in a tire valve stem so that it is sealed, and then use a normal tire inflator to pressurize the system.
So that is where I would suggest starting. then spray every fitting and boot with soapy water and start checking.
post #3 of 10 (permalink) Old 06-04-2010, 05:57 PM Thread Starter
They are getting pretty old I was thinking about just going ahead and replacing them. Any suggestions on a good set of after market boots?
post #4 of 10 (permalink) Old 06-04-2010, 07:44 PM
Mr Bobs boots they hold up to 125+ boost pressure and nitrous use. They are not cheap but they will not leave you with issues. Did you check the drivers boot by the fender at the intercooler a lot of them rub holes there.
01quadcab is offline
post #5 of 10 (permalink) Old 06-05-2010, 05:36 PM Thread Starter
I checked that a long time ago and had a slight wear in the boot so Im thinking it might have just finally given its getting worse, I cant hold over 21 now.
post #6 of 10 (permalink) Old 06-06-2010, 01:34 PM
2nd Gen Guru
Mopar1973Man's Avatar
I would build a turbo cap and pressure the system looking for leaks with soapy water (bubbles)...
You might also check your wastegate it might be sticking open?
Mopar1973Man is offline
post #7 of 10 (permalink) Old 06-06-2010, 04:22 PM Thread Starter
How would I get the waste gate back closed and do you think it would still hold 21 psi with it stuck open?
post #8 of 10 (permalink) Old 06-07-2010, 08:32 PM Thread Starter
Well I took it in today to get another opinion and turns out I have a big leak in the manifold gasket. So they wanted to charge me 500 to fix it after parts and labor. Said thanks but no thanks so with parts and a diagnostic fee Ill be walking out the door about 140. One thing he also mentioned was that the two bolts that hold on the heater/filter (which I no longer have on there) help hold down the manifold...... I was not aware of this, Mopar hopefully you can step in and give a little advice.
Any advice in installing the new gaskets and or bolts... is greatly appreciated.
post #9 of 10 (permalink) Old 06-11-2010, 04:32 AM
IDImonsterstack's Avatar
my stock turbo with the juice and the wastegate open all the way i would still hit like 28psi with the hx35 and with my injectors i can hit bout 40 but try to keep it under 35
under the knife for rebuild
IDImonsterstack is offline
post #10 of 10 (permalink) Old 06-11-2010, 06:26 AM Thread Starter
Im thinking its normal, I got the new gaskets in and everything and I swear its a new truck. amazing how much 9 or 10 pounds of boost can effect the ride. Ive seen 30 and am happy, I dont think I have nearly enough fuel to push 35 right now anyways. On top of all that the highest temps i have seen so far are just over 1100 which is a big improvement.
Thinking my ICP is bad smokeem 2003-2007 6.0L Power Stroke 3 09-22-2009 09:59 PM
Thinking about a 12v. sstockton 5.9L Cummins 12 Valve (1994-1998.5) 12 08-19-2007 06:30 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
WTF Were We Thinking ? fordt The Parking Lot 97 12-06-2006 12:24 PM
