starter solinoid fuse - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 3 replies and been viewed 798 times.
post #1 of 4 (permalink) Old 06-11-2010, 01:01 AM Thread Starter
So my starter solinod fuse blew memorial day. I put a new one in thinking It would happen again, it did went thrugh two fuses today. I havent looked at it real close the wires look good a little corowded but not to bad. Im thinking it might be time for a new starter- or at least a new solinoid any ideas?
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #2 of 4 (permalink) Old 06-11-2010, 07:45 AM
There are contacts to repair the solinod, check the brush length while the starter is off.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 4 (permalink) Old 06-26-2010, 04:02 AM
2nd Gen Guru
Mopar1973Man's Avatar
I would check the solenoid out first... Pull the starter and inspect the solenoid lead stud...
This is a first gen starter I did...
Mopar1973Man is offline
post #4 of 4 (permalink) Old 06-26-2010, 05:11 PM
On 24vs there is a diode to protect some thing else when the solenoid contacts go high resistance OR the battery terminals. I think it was on the TDR. The factory did not find the need but the malfunction shows starting about 200k and can be solved with solenoid contacts, battery terminal service, replacement of weak/mismatched batteries, grounds or a combination of those.
keydl is offline
HEUI Injector solinoid question Dualie Medium and Heavy Duty 16 06-06-2010 06:42 PM
Shut-off Solinoid Overheating Joaquin Suave 5.9L Cummins 12 Valve (1994-1998.5) 3 05-03-2010 10:20 PM
Popping 30 amp starter fuse lilgsx 2003-2007 6.0L Power Stroke 0 04-28-2010 11:48 PM
Clutch packs or solinoid? McDiesel 2003-2007 6.0L Power Stroke 2 09-22-2009 11:58 AM
starter or starter selnoid? 96 stroker 1994-2003 7.3L Power Stroke 6 01-31-2008 03:23 PM
