Dually fender cover!!! HELP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Duo, this thread has received 8 replies and been viewed 987 times.
post #1 of 9 (permalink) Old 02-02-2009, 06:19 PM Thread Starter
Diesel Duo's Avatar
Exclamation Dually fender cover!!! HELP
I cannot find a 2004 3500 rear passenger dually wheel cover. Where would I locate such an item? I have been to LMC (no dually), No luck on E-bay!
Please tell me this is not a dealer part!?
Ryan
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
post #2 of 9 (permalink) Old 02-02-2009, 07:04 PM
Powered By Ford
FordRacing200's Avatar
its a dealer part
FordRacing200 is offline
The Following User Says Thank You to FordRacing200 For this addition to TDG:
Diesel Duo (02-02-2009)
post #3 of 9 (permalink) Old 02-03-2009, 12:25 AM Thread Starter
Diesel Duo's Avatar
Different types
I have noticed two different types of dually fender covers. The traditional bulbous ones we are all used too. Then there is this newer style that looks like a fender flare of sorts. I am pretty sure these are factory pieces. I have seen very few of them.
Here are my ?'s.
1. What year and or trim model did those come on.
2. Can one convert to the slender, lower profile one from the old model with ease.
3. Is there no aftermarket maker of dually fenders?
Thank You,
Ryan
post #4 of 9 (permalink) Old 02-09-2009, 05:55 PM
Powered By Ford
the mega-cab dually's had the flare type fenders, I haven't seen an aftermarket mfg. of dually fenders, and it should be easy to mount the smaller flares, just depends on if there is holes left in the bedside or not from the large ones..
post #5 of 9 (permalink) Old 02-09-2009, 06:03 PM
Banned
These guys might be able to help ya out.
http://www.duallyfendersusa.com/
wastedwagesracing is offline
post #6 of 9 (permalink) Old 02-09-2009, 06:39 PM
Detroit Diesel's Avatar
different styles
I believe the different styles of the fenders metioned above are refering to the megacab. on the megacab, there wasen't enough room for the traditional dually fender, so they use what looks like an overgrown fender flair. when they go to a long bed megacab, most convery back to the conventional. I am guessing that the fender is gone, or in to many pieces to repair? You might check with a local body shop, they have other sources for parts, they may also be able to repair it cheaper than replacing it.
Detroit Diesel is offline
post #7 of 9 (permalink) Old 02-10-2009, 02:53 PM
Try going to Car-Part.com if you still cant find it.
Red 2004.5 4X4 4DR Lng Bed, Edge EZ Chip, 4" MBRP Exhaust, No DPF, K&N Filter, GlowShift Gauges, 2" Leveling Kit, Bilstien 5100's, Amsoil Bypass/w 15W-40 and still upgrading.
ALSEMAN is offline
post #8 of 9 (permalink) Old 02-19-2009, 07:02 AM Thread Starter
Diesel Duo's Avatar
Sorry.
Been busy and did not see all the reply's. Thanks you all for your input! I appreciate it greatly! I do not know what he decided to do but I will contact him tomorrow and inform him of all his new options.
Thanks again!
post #9 of 9 (permalink) Old 02-19-2009, 03:52 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
Are you a Cummins Forum member? Guy on there with the username Cummins and RV Salvage parts out trucks all the time. In fact he just parted a dually not too long ago, maybe he has what you need.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
Fender flares for dually? Diesel Dog General Ford Truck and Excursion 1 01-25-2009 11:20 PM
Fender Flares for dually NEWFY General Dodge Discussion 0 04-11-2008 04:15 AM
93 Dually Fender Molding 95psdF250 5.9L Cummins (Pre 1994) 3 01-10-2008 05:23 AM
Dually fender chips Horsehaulin The Detailing, Paint & Bodyshop 4 07-19-2007 03:12 PM
dually iner fender liners Diesel Dog General Ford Truck and Excursion 3 01-29-2007 12:04 AM
