Problems with Inifinity audio system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by D-Man, this thread has received 6 replies and been viewed 874 times.
post #1 of 7 (permalink) Old 07-15-2009, 03:19 AM Thread Starter
Just purchased this truck. It has the six speaker infinity sound system.
Noticed some distortion on the right front door speaker on bass notes.
Was just going to replace that speaker then today, the drivers door speaker made some loud distortion sounds on the bass notes and then just quick working all together. So now i'm not sure if it is two speakers gone bad or the head unit. Don't want to take it to the dealer for a speaker problem and don't want to spend $210 on a pair of speakers if it is not the problem. Anyone have any ideas?
D-Man is offline
post #2 of 7 (permalink) Old 07-15-2009, 07:03 AM
MadvilleMustangs's Avatar
most the time the distortion sound might be because the material its set in is carrying vibrations... thus making sound itself.... but i doubt a 6x9 can sound that bad....it might be a speaker bout to blow? who nows? do you run with the volume at max alot? if so that could be the problem
2005Dodge Ram 2500 QuadCab
Gauges:
  • GlowShift Elite 7 EGT 0-2400*
  • Edge Attitude Monitor
Lighting:
  • Recon LED Cab Lights
  • Recon LED 3rd Brake Light
  • Recon LED Tail Lights w/ Halo Super White Reverse LED light
  • ANZO Black Headlights w/ Halo Platinum White Bulbs
Programmer:
  • Edge Juice Programming Module w/ Attitude Monitor
Intake:
  • BHAF
  • Gutted Torque Tube
  • Silencer Ring MIA
Rims/Tires:
  • 17'' KMC XD Series Hoss Rims, Black Chrome
  • 295/70r17 (33") Cooper Discoverer STT
Other:
  • Full Custom Front End Replacement
  • Custom Made Running Boards
  • 5% Limo Tint All-Around
MadvilleMustangs is offline
post #3 of 7 (permalink) Old 07-15-2009, 11:54 AM Thread Starter
Never have the volume turned up high. I don't like loud music. The driver door speaker isn't working at all but this morning it worked with high distortion for a few seconds, then make a loud distortion noise and quit working all together. It make that split second distortion noise again a few more times on my way to work.
D-Man is offline
post #4 of 7 (permalink) Old 07-15-2009, 08:11 PM
Kummins's Avatar
Check to see if the plug is loose on the speaker. More than likely the speaker is blown although it could also be that channel is having a problem such as grounding out.
So first check the plug on the speaker to make sure it's plugged in. If it is then find another speaker and see what that sounds like. If the other speaker sounds better then your speaker is blown. If the other speaker sounds the same then you have a problem with that channel. If you do have a problem with that channel check the wires all the way to the head to make sure it's not grounding out somewhere. If it isn't then it's the head unit.
Lots of stuff you can check for free before buying anything.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #5 of 7 (permalink) Old 07-16-2009, 12:37 AM Thread Starter
It seems as though, both speakers are blown. I switched the speaker that doesn't work at all with the one that sounds bad and the problems stayed with the speaker. So, I'm going to order two new ones. $75 each OUCH!
I was told I can't use any other speaker with this system. Anyone want to confirm that?
D-Man is offline
post #6 of 7 (permalink) Old 07-16-2009, 08:29 AM
i really dont see why you cant use any other speaker.... i mean.... a speaker is a speaker.... if you really wanted to... you could mod your door to hold 13'' subwoofers... but anyways... again... a speaker is a speaker and all I can see you having to do is doing a bit of rewiring...
Gauges:
Lighting:
Programmer:
Intake:
  • BHAF
  • Silencer Ring MIA
Rims/Tires:
Other:
post #7 of 7 (permalink) Old 07-16-2009, 03:26 PM
Formerly F350_Beast
Cummins_Beast's Avatar
If you don't want to run new wires you can't use any other speakers. Been there, done that..what a huge headache!
// BENNY \\
14.7 @94mph
// 2006 Dodge Ram 2500 5.9 Cummins QC 4x4 Laramie \\
// 4" Lift, 35" Nitto Mud Graps, 20" Moto Metal 955's \\
// Silencer Ring M.I.A, aFe Mega Cannon, Edge Juice w/ Attitude, 5" TBE \\
'97 F350 SOLD
--RIDING HIGH CLUB MEMBER #4 --
SINGLES CLUB MEMBER #95--
Cummins_Beast is offline
Charging system problems ramitharder 5.9L Cummins (2003-2007.5) 0 03-09-2009 12:52 PM
Okay boys... Lets See Your System... (I know some of you are audio nuts like myself) bigvick General Parts and Accessories 22 01-06-2008 06:38 AM
Audio system help diesel_ram_man General Parts and Accessories 14 06-23-2007 08:48 PM
audio* 3 J L audio 12w6s / SUPERUTY Crewcab box jpmartins Whats Been Sold 21 01-26-2006 01:54 AM
Audio system 3 months old!!!! bagstroke Whats Been Sold 0 08-12-2005 02:26 AM
