Boost questions - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokd2dmax, this thread has received 24 replies and been viewed 4595 times.
post #11 of 25 (permalink) Old 11-08-2010, 05:14 PM Thread Starter
Diesel Enthusiast
Originally Posted by BriteWhiteRam View Post
i would be careful with running too much boost, i was only running 30psi when my HG's took a dump, and its a 20+ hour job to replace them
Ouch yeah I am kinda worried about that. What tune were you running to get 30lbs? Does the pcm throw an overboost code with the boost increase valve? I was under the impression that it didn't. Would you recommend headstuds+gasket for 30? I might just have to run a lower setting on the ppe if she does 30.
Smokd2dmax is offline
post #12 of 25 (permalink) Old 11-09-2010, 04:16 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
ok well this situation may be different, I have an LBZ, so i dont have a wastegated turbo, its a VGT instead, and i WAS running a tune of my own creation, i used a Duramaxtuner tune and added more fuel and timing i estimated at 400rwhp, as well as a turbo-brake script, however Im just running a 365rwhp tune now, no turbo brake
EFI can tune out any over boost codes, basically any code you want to eliminate it can
I dont know if the LB7's blow gaskets, but i would think that 30 is pushing the limits, I found out the hard way that gaskets go quite regularly on LBZ's, and they always go the same way, but the new gaskets i have are supposed to hold up quite well, and i was told that regular headbolts should be able to hold 40psi if torqued properly
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #13 of 25 (permalink) Old 11-09-2010, 02:14 PM Thread Starter
Diesel Enthusiast
Okay well I might put in new gaskets and retorque mine before I have problems...the headstud kits I have seen have all been like $600+
post #14 of 25 (permalink) Old 11-09-2010, 07:53 PM
Gone Fishin...
merlin5577's Avatar
For the amount of effort it takes to do head gaskets on these trucks, if your going to pull the engine apart to replace the gaskets, do yourself the favor and get the stud kit. That way you wont have to do the job twice.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #15 of 25 (permalink) Old 11-09-2010, 09:52 PM Thread Starter
Diesel Enthusiast
Right on man. Is there anybody (reliably)running over 30psi in their lb7's?
post #16 of 25 (permalink) Old 11-13-2010, 06:35 PM
CRAZY CANUCK
http://www.merchant-automotive.com/l...gasketkit.aspx
Thats the Merchant Automotive kit, probably the cheapest Kit out there and its $1031.95 With ARP studs
You CANNOT re-torque the stock head bolts, they are a TORQUE-TO-YEILD bolt, they actually stretch when they are torqued, once they have failed, or are removed they will no longer be any good, they are a one time use only bolt, and there are 32 of them
Ridin Dirty Club #5
TDG TOTQ
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
Smokd2dmax (11-15-2010)
post #17 of 25 (permalink) Old 11-15-2010, 01:32 PM Thread Starter
Diesel Enthusiast
Well I guess I better start saving for the stud kit before I put that boost increase valve in I'd rather be safe than blow a headgasket over a few extra psi.
post #18 of 25 (permalink) Old 11-15-2010, 11:41 PM
Gone Fishin...
merlin5577's Avatar
Not without studs...
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #19 of 25 (permalink) Old 11-16-2010, 12:20 AM
CRAZY CANUCK
Eric Told me that 40psi is possible with stock bolts on an LBZ, as for an LB7 i dont know
Its more about cylinder pressures than boost pressure, besides lots of extra boost on a stock turbo really isnt gaining you anything, just lots of heat and a turbo running outside of its effective MAP
Ridin Dirty Club #5
TDG TOTQ
post #20 of 25 (permalink) Old 07-10-2012, 06:39 AM
Gentlemen not to sound like a complete noob, but is there a reference I can refer to in order to learn all the abrivations you folks Speke so fluently ? Thank you in advance
Good luck
God speed
Sent from my iPad using Tapatalk
glock36 is offline
boost gauges questions Sabbath5.9 5.9L Cummins 12 Valve (1994-1998.5) 2 09-17-2009 02:42 AM
Boost psi questions iwannagofast 5.9L Cummins (1998.5-2002) 2 11-13-2007 07:40 AM
Questions about boost and problems thefatkid 2003-2007 6.0L Power Stroke 23 03-24-2007 12:48 AM
boost questions jmt1975 1994-2003 7.3L Power Stroke 1 11-24-2006 09:05 PM
ATS and Boost questions Diesel Dog General Ford Truck and Excursion 1 06-06-2006 04:27 PM
