What would happen if.... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TheBac, this thread has received 6 replies and been viewed 694 times.
post #1 of 7 (permalink) Old 11-07-2006, 02:57 AM Thread Starter
You ran a Duramax without an intercooler?
Would missing it affect the turbo at all?
Would not having it mess with the ECM programming?
What would the likely power drop be?
I'm just curious....
TheBac is offline
post #2 of 7 (permalink) Old 11-07-2006, 12:48 PM
With all the extra heat in the air you yould have super high egt's and lower performance. Every 1 degree warmer the intake is, its 3 degrees of egt.
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #3 of 7 (permalink) Old 11-09-2006, 11:17 PM
no intercooler engine runs hotter u lose horsepower.
stumppuller is offline
post #4 of 7 (permalink) Old 11-10-2006, 02:52 AM Thread Starter
I kind of figured that. But to compensate, would you have to run a different tune to lower boost?
TheBac is offline
post #5 of 7 (permalink) Old 11-13-2006, 12:02 PM
i had to turn up boost after intercooler was installed to get the same boost.
post #6 of 7 (permalink) Old 11-26-2006, 09:52 PM
i've heard of sled pullers running no ic, but they snort a whole lot of water meth to keep egt's down, but looking at it respectively without the heat factor, you will gain horsepower because there is no boost loss because there is no ic.
samfraser is offline
post #7 of 7 (permalink) Old 12-06-2006, 03:26 AM
u would just have to use water without the ic to keep it the egt down. that what we do on the pulling truck
fwdcummins is offline
Closed Thread
