Duramax Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dieselwrencher, this thread has received 9 replies and been viewed 829 times.
post #1 of 10 (permalink) Old 11-30-2006, 01:45 AM Thread Starter
TDG Mafia Member #56
Dieselwrencher's Avatar
Duramax Question
Hey guys, I have a quick question I know you Chevy guys can answer for me. How do you distinguish between the LLY and the LBZ? Is one just newer than the other, or is it an option? I don't work on many Duramaxs' and I am curious for future reference. Thanks for any help guys, Ryan.
Putco light bar
Dieselwrencher is offline
post #2 of 10 (permalink) Old 11-30-2006, 02:03 AM
Look at he VIN for one. 8th digit is the engine ID.
1 - LB7
2 - LLY
D - LBZ
The engine year splits are thus:
2001 - 2004.5 - LB7
2004.5 - 2005 - LLY (1st Gen)
2006 - 2006.5 - LLY (2nd Gen)
2006.5 - 2007 - LBZ
2008 - ?????? - LMM
The 2006 LLY and the LBZ are pretty much the same engine. It is surmised that the only real difference between them is programming.
TheBac is offline
post #3 of 10 (permalink) Old 11-30-2006, 04:19 AM Thread Starter
Thanks for the detailed info, this really helps out.
Putco light bar
post #4 of 10 (permalink) Old 12-03-2006, 04:44 AM
TDG Junior Mafia #61
Dieselson's Avatar
Some specs are
LLY: 310 HP 590 Tq
LBZ: 360HP 650 tq
I also think LBZs use different pistons, which are very popular among high performance guys. There are other things too. Very very quite too, I'd say under 70 db at idle.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #5 of 10 (permalink) Old 12-03-2006, 12:28 PM
Dieselson...do you know of anyone whos torn apart a 2006 LLY? Since I'm one of those people that think the only diff between the LLY and LBZ in 2006 is the prgramming, I think it would be interesting to see if those pistons and rods were the same.
TheBac is offline
post #6 of 10 (permalink) Old 12-06-2006, 01:03 AM
Dieselson's Avatar
Well, I'm not exactly sure about the pistons thing, they could be the same for all I know. All I know is that LBZ pistons are what all the high performance guys use, and I don't usually hear about LLY pistons being used.
TDG Mafia
The Diesel Garage
"Can you keep up??
post #7 of 10 (permalink) Old 12-06-2006, 01:55 AM
Supporting Vendor
The engine for the 06 is the same regardless of how its labeled. The mechanicals are 100% identical. The ONLY diff is the tuning in the computer.
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
post #8 of 10 (permalink) Old 12-06-2006, 04:01 PM
Dieselson's Avatar
Thanks eric, so if I used 06' LLY pistons, it would be the same as using LBZ pistons?
TDG Mafia
The Diesel Garage
"Can you keep up??
post #9 of 10 (permalink) Old 12-07-2006, 01:36 AM
Supporting Vendor
Yessir
Eric Merchant
Zeeland, MI
1-866-399-7169
post #10 of 10 (permalink) Old 12-07-2006, 01:47 PM
Thanks:Thumbup: Learn something new everyday! Should make 06 LLY/LBZ tuning on EFI interesting.
Closed Thread
