Questions about Quadzilla Commander? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chevyboy2004, this thread has received 4 replies and been viewed 668 times.
post #1 of 5 (permalink) Old 01-06-2007, 08:23 PM Thread Starter
ChevBeliever
Does anybody own a duramax with a Quadzilla Commander? I am looking for a monitor that works well with a duramax and is easy to use and understand.
if anybody can give me any insite on the subject!
Chevyboy2004 is offline
post #2 of 5 (permalink) Old 01-06-2007, 09:35 PM
If it works anything like the Edge Attitude monitor, then I would say its very easy to use. Being able to cycle through power levels and have a single screen with gauges is a bonus.
Have you checked Quad's site for more info?
TheBac is offline
post #3 of 5 (permalink) Old 01-15-2007, 04:52 PM
I've got one on my truck. Not a dmax but I can tell you that it is pretty easy to use and install. The instructions are darn good!!
If you are able to change power levels with it (not sure how that all works with the dmax) you just push the 2nd button in and you will go up or the 3rd button and it will go down one level.
I also have a pic of it insalled in my truck. It will give you a better idea of the size of the unit. It is in the link to my gallery.
Eric
Dually Club Member #53
racehauler is offline
post #4 of 5 (permalink) Old 01-15-2007, 05:01 PM
I have the commander on my PSD, and it is great, large display, easy to use, and you can do all kinds of stuff with it. I am sure it would be the same on a Duramax.
Logan is offline
post #5 of 5 (permalink) Old 01-17-2007, 07:14 AM
DPDIESEL's Avatar
It works very well on the D-Max. It doesn't change power levels if you are using a downloader but if you are using a plug in module it will. Shoot me a PM for some more info and a price. :Thumbup:
Performance Diesel Motorsports
5,500 RPM Common Rail Anyone??
DPDIESEL is offline
Closed Thread
