What's the fastest Dmax on #2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by noreaster, this thread has received 11 replies and been viewed 1756 times.
Closed Thread
post #1 of 12 (permalink) Old 07-16-2005, 05:23 AM Thread Starter
I'll ask this in a few parts,
1. Who is the fastest Dmax on #2 with stock turbo & injectors, figuring bolt-on stuff like programmer, exhaust, intake, wastegate actuator, fuel pump.
2. Street tire times vs. slicks. I'm including Dot slicks with slicks, since they are closer to slick than actual tires that you would drive around normally on.
3. Bigger turbo, injectors & what ever else mods. that can be done.
4. Same thing as question #2, associated with #3.
If you are willing include weight of truck when that time was run.
noreaster is offline
post #2 of 12 (permalink) Old 07-16-2005, 03:00 PM
DPM Mobile Dyno
To my knowledge, Buck and Jess have the stock turbo/injector truck record and NLDP the aftermarket Turbo one.
I don't know there weights but are no less than 6200.
David Dunbar
www.runNADM.com
www.DieselPerformanceMotorsports.com
2004.5 Dodge 3500 Laramie 4x4 48re
1998 Dodge 2500 QC 4x4 12v 47re
Power by Garmon - to the ground by Sun Coast = 12's :Thumbup:
DavidTD is offline
post #3 of 12 (permalink) Old 07-16-2005, 04:26 PM
straight #2 Tomac was in the 12.4 to 12.5 range i think with stock charger and sticks, carbon04 from the place is around there too, neither that i know off were running slicks, jeremy moss put down 12.7s with mudders on, and i went 13 flat with 305s, ryanu was 12.8 with 325s, not bad for programming and trans work
DaleS is offline
post #4 of 12 (permalink) Old 07-17-2005, 05:34 AM Thread Starter
What did Buck & Jess run on fuel only? I know it's fast as hell with other stuff.
No Limit, what did you run at Indy, 12.??
post #5 of 12 (permalink) Old 07-17-2005, 02:05 PM
Smokers Anonymous
11.07 @ 123.32
No Limit Diesel Performance
01' Dmax that Drags and Pulls [email protected]+
My Pic's
2001 F350 4X4 PSD with some stuff
Howling is offline
post #6 of 12 (permalink) Old 07-17-2005, 09:19 PM Thread Starter
I remeber the 11 sec. run, asking about fuel only run.
post #7 of 12 (permalink) Old 07-18-2005, 12:17 AM
We only made one run on fuel do to having only 3 or 4 passes for qualifing .We ran 12.3 1st pass left ok not well though.NLDP
NO LIMIT is offline
post #8 of 12 (permalink) Old 07-18-2005, 01:16 AM Thread Starter
What did you guys run last year with stock turbo & sticks?
& Steve, any input to this, since your tune is the fastest.
post #9 of 12 (permalink) Old 07-18-2005, 04:33 AM
Last year were stock injects, and we are still tuning the tuning lol.NLDP
NO LIMIT is offline
post #10 of 12 (permalink) Old 07-18-2005, 04:47 AM
Right now No Limit is sorting out some of the issues with all of his changes. Once things get settled down with the truck I'm sure we can step it up. Right now everything just needs some time to sort it all out. They worked hard to make it to Indy without anytime to do much testing. Now they are going back over it and we will get the testing done and make adjustments as necessary.
Diesel Tech is offline
Closed Thread
Nothins sold yet... 6L strokin Whats Been Sold 52 01-04-2009 11:25 PM
LLY Cooling Fan Pulley Replacement (6.6L (LLY) Engine) ripmf666 GM Spec Info 0 12-28-2008 01:24 PM
Which CPS are you running? calebgriffin31 1994-2003 7.3L Power Stroke 2 12-23-2008 11:03 PM
Banjo Bolt Question... DSI 2003-2007 6.0L Power Stroke 2 09-08-2005 11:59 PM
99-04 Superduty chrome grills-new larpy Whats Been Sold 4 08-25-2005 01:18 AM
