Timing and... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by killerbee, this thread has received 5 replies and been viewed 882 times.
post #1 of 6 (permalink) Old 02-13-2007, 07:46 PM Thread Starter
BUG JUICER and
Timing and...
Optimized timing is that which results in the most fuel combustion energy being delivered to the crank in the form of rotational torque, and ultimately to the wheels. It is where our 35% engine efficiency comes from at WOT. (2/3rds of fuel running through the motor is wasted heat.)
I have been doing some research and it seems we often overadvance our tuning.
Timing and boost. Adding boost, speeds up the flame front, so timing must be retarted to prevent that coveted efficiency from going south.
Timing and IAT. Same thing
just starting a discussion thread. The moment you jump off the 5 second dyno, everything changes. Intake charge might be 100 degrees for a race launch, but after 5 minutes towing up a grade, 200 degrees. Yet no timing change. Add the increasing cyl head temp. Fuel with increased Cetane. Dry environments, even a free flowing exhaust. All these factors add to the requirement to retard for optimization.
I just seem to have it stuck in my head, advance is possibly overused, particularly when dyno tuning.
Timing and ....
Michael
04.5 GMC 2500HD SRW LLY
ECM's FOR SALE
killerbee is offline
post #2 of 6 (permalink) Old 02-17-2007, 05:24 AM
Tire Smoker
bobo's Avatar
Send a message via AIM to bobo Send a message via Yahoo to bobo
Where did you get your info that warm air advances timing? It is very much the opposite. That is the reason for a pilot injection pulse. That warms the air and makes the fuel/air mixture less volatile. The mixture starts to burn sooner and lasts longer with warm air.
In Lehman's terms, increasing boost increases the compression ratio. These motors are compression ignition.....you get the idea.
Bobo's Truck Website
Special Thanks to: Huckstorf Diesel, Merchant Automotive, EFILive, Mike L. @ Inglewood Transmission
05 Twin Turbo Duramax
[email protected]+ on #2 only
bobo is offline
post #3 of 6 (permalink) Old 02-17-2007, 01:04 PM Thread Starter
BUG JUICER and
I think we agree Bob. My terminology may have been poor.
-Increasing IAT has the effect of advancing ignition.
-Increasing boost has the effect of advancing ignition
-The pilot injection pulse permits the main charge to be retarded, when optimizing timing
Diesel or otherwise. Better?
Michael
ECM's FOR SALE
post #4 of 6 (permalink) Old 02-17-2007, 01:07 PM
pilot inj is for noise reduction, multiple small shots to quiet down combustion process, so it does not sound like a 24v isb cummins.by the way our trucks turn off the pilot inj when its revved above 25-2600 rpm because of federal mandated emmisions it does not pass at those rpms with pilot inj on.
dmaxvaz is offline
post #5 of 6 (permalink) Old 02-17-2007, 03:06 PM Thread Starter
BUG JUICER and
true, as well as nox production, but pilot inj has an impact on timing optimization. Pilot inj reduces main ignition delay, requiring the tuner to retard timing for optimization.
Michael
ECM's FOR SALE
post #6 of 6 (permalink) Old 02-17-2007, 04:33 PM Thread Starter
BUG JUICER and
Timing and...coolant temperature
ECT is more or less, engine temperature. If engine temperature increases, say from 190 to 230, this has an impact on final charge temp. So we would need to retard timing as ECT increases, to maintain optimized timing.
Michael
ECM's FOR SALE
Closed Thread
