8.2 diesel in chevy bus - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sbusald, this thread has received 4 replies and been viewed 7969 times.
post #1 of 5 (permalink) Old 02-22-2007, 01:19 AM Thread Starter
buddys got a 8.2 in a chevey bus and wants it turned up, whats the best way to do this to one. he basically uses it as a camper but pulls a trailer with it with off road vehicles on it. he needs power but it needs to hold up. it has the allison behind it. thanks
sbusald is offline
post #2 of 5 (permalink) Old 02-22-2007, 02:54 AM
this is all i could find, this is from dale (nevrenufhp)
Detroit 8.2L:
Tools needed-screwdriver and I think it's a 9/16" wrench. On top-middle of the pump on the right side there's an all-thread looking screw with a jamb nut. Loosen the jamb nut and take the screw out. There's a spring inside it, so be cautious. Run the jamb nut so there's about 4-5 threads left and re-install the screw. Run it up to the jamb nut, then tighten the nut up and it's done. Not much, but it's free.
DBogo is offline
post #3 of 5 (permalink) Old 03-08-2007, 05:15 PM
You cant turn those v-8's up too much, if you want them to hodl together.
#23 Singles Club
thejdman04 is offline
post #4 of 5 (permalink) Old 03-10-2007, 01:37 PM
turning the fuel screw,will only net a bit of a hp change. to get any drastic change,you must change out the injectors . as mentioned,this v8 was not a well designed engine,hard work,and high hp levels are a recipe for disaster with this engine. i have had/have 3 of them.
navistar45 is offline
post #5 of 5 (permalink) Old 03-10-2007, 03:30 PM
Super Moderator
John_G's Avatar
Originally Posted by sbusald
buddys got a 8.2 in a chevey bus and wants it turned up... he needs power but it needs to hold up. thanks
You can't have either, let alone BOTH more power AND durability.
The 8.2L was CRAP in stock trim and power in terms of reliability. You want to talk about cracked heads, leaking injector tubes, and headgaskets?!?! The WORST engine ever produced for those problems.
The issue with the DD 8.2L was that they did not have ANY material at the top of the cylinders. Yup, none. Just the outside edge of the block and the cylinders, no "deck" on top at all. This causes the cylinder walls to flex and move, and the cylinder heads to flex as well. BAD idea.
The DD 8.2L NA was rated from 130-180 HP, while the DD 8.2L-T was rated from 170-210 (or 230 HP I don't recall any more). That's 8.2L, turbocharged that WOULD NOT LIVE at 210 HP, not even 50,000 miles.
Compare that to the International DTA 360. 210 HP, 750 lb-ft and they lived w/o any troubles to 225,000 and weighed a LOT less.
If you mess with the Gov on one of these, you had BETTER know what you are doing. More than one block has been ventilated due to excessive RPM after someone turned a Gov screw.
I know, we had 16 of them, and I have done headgaskets over 200 times on them. EEeeewwww
I vote for LIBERTY!
John_G is offline
Closed Thread
