Gauge opinions needed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by killerbee, this thread has received 14 replies and been viewed 1543 times.
Closed Thread
post #1 of 15 (permalink) Old 02-23-2007, 07:14 PM Thread Starter
BUG JUICER and
With a shortage of space for gauges, i want to find out if there is interest in these aircraft type gauges. Allows 2 readings, and I am looking at white face special order as well.
http://www.westach.com/old/images/sh...-Boost-EGT.jpg
I want to market a gauge that shows boost on one side, and cool charge (post intercooler) temperature on the other.
Thoughts?
Michael
04.5 GMC 2500HD SRW LLY
ECM's FOR SALE
killerbee is offline
post #2 of 15 (permalink) Old 02-23-2007, 07:28 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
I would have to see something like this in person. It is really confusing cause in that pic when everything should be reading 0 it look like it could be reading 5-6K in EGTS and 12 psi boost :shrug:
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 15 (permalink) Old 02-23-2007, 08:51 PM Thread Starter
BUG JUICER and
I see what you mean. Just look at the red. Forget it is a needle. One thing I would ask them to do is make the needle (except the tip) the same color as the background
Michael
ECM's FOR SALE
post #4 of 15 (permalink) Old 02-23-2007, 08:53 PM Thread Starter
BUG JUICER and
ANOTHER
white face plus white needle. Less confusing?
Michael
ECM's FOR SALE
post #5 of 15 (permalink) Old 02-28-2007, 10:38 PM
I am perfectly happy with the X-Monitor. It doesn't take up a lot of room, and is digital, with memory.
hdmax2002 is offline
post #6 of 15 (permalink) Old 02-28-2007, 11:08 PM
CSIPSD's Avatar
Second one is better. I dont really like the look but if they came up with a Intake air and post IC air temp gauge that would be cool!
CSIPSD is offline
post #7 of 15 (permalink) Old 02-28-2007, 11:41 PM Thread Starter
BUG JUICER and
aren't they the same?
If you knew that compressor temps range from 200 to 600F, would you want to know that?
Michael
ECM's FOR SALE
post #8 of 15 (permalink) Old 04-02-2007, 01:17 PM
TDG Member Since 2004?
KarTek's Avatar
It looks something like this helicopter RPM gauge:
http://www.cybercom.net/~copters/mec...s/R22_tach.jpg
Makes me nervous when the needles don't match!
-Evan
2000 Ford F250, Merillion, 6sp, AIC, DPTuner, BB turbo, Adreneline pump, modified IDM.
1998 Mercedes E300, Custom injector nozzles, soon to have Eaton M90 supercharger, 7.5mm pump elements, Holset HX40 turbo and a full custom intake and exhaust system = 400HP from 3.0l
KarTek is offline
post #9 of 15 (permalink) Old 04-13-2007, 04:28 AM
The only issue I have ever had with the Westach gauges is they are very busy in the smaller sizes (under 3") that get used in pickups and cars. They make the bigger sizes and it works well for reading them but take up more space. I do not think you can do much in the limiter space of a 2" gauge to make it any better. You really need to look at the gauge to get a reading instead of glancing at them to know with the dual readouts and small sizes.
Diesel Tech is offline
post #10 of 15 (permalink) Old 04-24-2007, 03:02 PM Thread Starter
BUG JUICER and
I have another idea in the works.
It is very cooool. A gauge that will display any parameter that is scannable, over 40 common parameters. It even plugs into the obd port. You can even read and clear DTC's, log 0-60 times, etc.
When I get it, I'll take some pics.
Michael
ECM's FOR SALE
Closed Thread
