Nitrous is in... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 05 2500HD, this thread has received 5 replies and been viewed 1291 times.
post #1 of 6 (permalink) Old 08-10-2005, 08:21 AM Thread Starter
Nitrous is in...
and running. :evil: I gave in to the addiction and now I am snorting the good stuff! Decided to step it up a notch. I decided to mount inside the cab, as you can see from the pictures.
It's a tight fit back there with a 15lb. bottle, but I managed to shoe horn it.
I decided to install the brackets on a mount I had laying around from some other project (house related). Worked out well; didn't drill any holes to mount the bottle brackets. I just used the existing holes for the plastic flap thing that was removed for the bottle. Only hole I drilled was under the driver side panel (door jam). Besides that, there was already a hole underneath the cab that has a grommet, which I used to route the line to the solenoid.
Just thought I would share my experiences with the setup for anyone else out there pondering where to install the bottle. Oh yeah, still have to get another hose for the blow down. Better hurry for Friday or else the track might not let me run. Here are some misc. pics. Enjoy!) Any comments are welcomed!
05 2500HD is offline
post #2 of 6 (permalink) Old 08-20-2005, 07:47 PM
Nice setup :Thumbup: Let us know how you do with it in 1/4 mile.
slowford is offline
post #3 of 6 (permalink) Old 08-26-2005, 09:13 PM
If you go to the track and they see it behind your seat, they won't let you run it unless you have a tube running from the blow-off valve to outside the cab. If it were to blow off from excessive pressure, it would be trapped inside the cab and you will get sick real quick.
BOWTY is offline
post #4 of 6 (permalink) Old 08-26-2005, 09:55 PM
Or he may just laugh alot......:Thumbup:
Timbeaux38 is offline
post #5 of 6 (permalink) Old 08-27-2005, 04:24 AM
Kat
He has a blow down tube so all is good :Thumbup:
Kat is offline
post #6 of 6 (permalink) Old 08-27-2005, 04:58 PM
Good, I just didn't want him to get to the track and not be able to use it. In the picture its not in yet.
BOWTY is offline
Closed Thread
Engine Overheating rwhite 5.9L Cummins (1998.5-2002) 5 01-02-2009 08:39 PM
SCT XCAL2 Group Buy for TDG Memebers ONLY!!!! biavaperformance Supporting Vendors Forum 24 11-27-2005 06:58 AM
Speedo recalibration ?????? Rww 2003-2007 6.0L Power Stroke 7 10-27-2005 04:22 PM
Turbo Sound UpstateDieselGuy 2003-2007 6.0L Power Stroke 4 09-02-2005 09:45 AM
EGR Cleaning dwelch1 2003-2007 6.0L Power Stroke 6 08-18-2005 05:34 PM
