2001 questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 14 replies and been viewed 2207 times.
Closed Thread
post #1 of 15 (permalink) Old 07-05-2007, 05:34 AM Thread Starter
2001 questions
ok going to put an exhaust on a 2001 dmax and was wondering if removing the cat was going to be a problem and throw codes if so how do you get rid of it? does this truck have an egr? Is it a good idea to remove it? If so what do you do how and what about codes?
not my truck it's my neighbors and I just research for him. Thanks for the input and yes it's a california truck
01quadcab is offline
post #2 of 15 (permalink) Old 07-05-2007, 04:59 PM
no u should be find and it does not have a egr i have a 05 lly with all that stuff on it and i have took the cat out and never had a problem
fwdcummins is offline
post #3 of 15 (permalink) Old 07-05-2007, 09:06 PM
TDG Junior Mafia #61
Dieselson's Avatar
An 01' should not have a cat, look under the truck.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #4 of 15 (permalink) Old 07-06-2007, 12:18 AM
I thought all LB7 Cali trucks came with cat and egr, even 2001s?
Not sure if Fingers made a Fingerstick for an LB7 EGR system, did he?
TheBac is offline
post #5 of 15 (permalink) Old 07-06-2007, 02:05 AM Thread Starter
I looked under truck before i started the thread it does have a cat unless it's got 2 muffs..
post #6 of 15 (permalink) Old 07-06-2007, 03:08 AM
I did some checking. If you remove the cat on an 01, it will probably set some codes in the computer, and it MIGHT set a check engine light. I say might because some people have had it light, while others haven't.
Yes, a Cali LB7 has an EGR. You can use an LLY blocker plate to block it off. I guess they are the same shape. Fingers didnt make an LB7 fingerstick to head off an codes, though.
I also read about Cali LB7s having air pumps. You can either block the vacuum line at the EGR or remove the pump (just run the belt the same way -- it can take up the slack). BUT, you'll set codes doing this, too.
Looks like the only way to remove the codes is to use EFI live to remove them. Maybe you can get ahold of SoCalDiesel (Guy Tripp) and see if he can help you with that?
Hope that helps.
TheBac is offline
post #7 of 15 (permalink) Old 07-06-2007, 04:21 AM Thread Starter
thanks that helps a lot. I will have to see what I can do to fix this. just want his egt's down and no engine codes
post #8 of 15 (permalink) Old 07-06-2007, 05:18 AM Thread Starter
so other than efi live it needs a cat?
post #9 of 15 (permalink) Old 07-07-2007, 04:58 PM
Dieselson's Avatar
Our 01' that was delivered in acalifornia, which means its a california truck has no EGR or cat, from the factory.
TDG Mafia
The Diesel Garage
"Can you keep up??
post #10 of 15 (permalink) Old 07-07-2007, 11:03 PM Thread Starter
well dam I guess I should go take a pic of the dam thing. you may of just been lucky and got a non ca style one or something maybe the first few outta the factory or he just got a ******* case I dunno. I just know it has a cat as for an egr or anything I have not looked
Closed Thread
