changeing rear end gear ratio - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 6 replies and been viewed 1463 times.
post #1 of 7 (permalink) Old 07-08-2007, 04:41 PM Thread Starter
pontiacross's Avatar
my brother is looking at buying a 01 to 04 2wd 2500 with a 6 speed and duramax, and is gonna try and see how much fuel economy he can get out of it. he is wanting to swap in a different set of gears around 3.08's but we are having trouble finding any or even what rear end it has. I know the gear vendor is an option but its a bit pricey and he wont be pulling any big loads so the taller gears wont hurt any thing
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 7 (permalink) Old 07-08-2007, 07:17 PM
3.73's were standard on Dmaxs. I think the only gear options out there are 4.10s.
He could put 285's on the truck to lower the ratio, too. Dont know if it would help mileage, though.
TheBac is offline
post #3 of 7 (permalink) Old 07-08-2007, 08:45 PM
I believe the d'maxs all came w/ the GM11.5" rear end. Don't know if there are to many ratios availible though.
I would just put on taller tires to effectively increase the ratio.
:2cents
Dual K20s is offline
post #4 of 7 (permalink) Old 07-08-2007, 09:39 PM
TDG Mafia # 81
Horsehaulin's Avatar
Diesels are work engines, built and intended to pull heavy loads efficiantly. If he wants good economy out of a diesel, then tell him to buy a VW with a TDI. Those cars get around 40-50MPG. A GM truck is nothing more than a big wind break with a strong engine, not really a economical truck by any means.
Just my .02,
Tony
Horsehaulin is offline
post #5 of 7 (permalink) Old 07-08-2007, 10:23 PM
TDG Junior Mafia #61
Dieselson's Avatar
No one makes anything lower than a 3.73 for the AAM 11.5 14 Bolt. Its from 3.73-5.13 for that axle.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #6 of 7 (permalink) Old 07-09-2007, 12:29 AM Thread Starter
Just my .02,
Tony
he will be pulling a light load every now and then so heed needs something more than a small car or pickup. he isn't expecting 40 to 50 mpg just hoping for mid 20's
we thought a different gear ratio would be an easy change that might make a big difference but if nothing taller than 3.73's is available he can probably get decent fuel mileage out of it without it.
Ross
Tow Rig
post #7 of 7 (permalink) Old 07-11-2007, 04:51 AM
TDG Mafia # 81
I gotcha, I didnt realize he was going to use it to tow with at times. That makes sense. I wasnt trying to insult him, but I think he should get around 20MPG with a DMAX. My neighbor gets 22-23hgwy. Hes got a few mods, but nothing like EFI Live.
Tony
Closed Thread
