Which drivetrain combo best for all out performance? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tyrod, this thread has received 12 replies and been viewed 1579 times.
Closed Thread
post #1 of 13 (permalink) Old 10-13-2007, 03:20 PM Thread Starter
Thought about building a hot small block chevy but the Dmax seems be as quick for a lot less money. I am not familiar with all the engine codes. 2wd or 4wd? Auto or manual? Low 13's goal.
02 F250 CC, 4X4,SB. DP Tunes stk, 80econ,120. NAPA 6637 air element. Summit 4" turboback. GDS hi-flo outlet. 1.0 turbine housing. HX cross-over. Modded pedestal. CCV mod. Fuel rails connected. AIH delete, pre-pump.
Tyrod is offline
post #2 of 13 (permalink) Old 10-15-2007, 04:01 PM
fordt
8th digit in the Vin -
1 - LB7
2 - LLY
D - LBZ
I would go with an auto for sure, the manuals are also hard to find.
post #3 of 13 (permalink) Old 10-15-2007, 11:27 PM
4x4 so it hooks up, and then you still ahve a usable truck, auto lbz
#23 Singles Club
thejdman04 is offline
post #4 of 13 (permalink) Old 10-20-2007, 08:06 PM
https://www.thedieselgarage.com/forum...695#post486695
this should answer all q's about buildin-em up
cajuncummins is offline
post #5 of 13 (permalink) Old 10-21-2007, 12:06 AM
I wouldn't consider building a Dmax to be less expensive than an SBC. Think of it in reverse...you simply need a programmer and exhaust for the engine (intakes are optional) but you have to spend the $$ to build the trans to hold the power.
Most definitely want a 4x4, though. Reg Cab would be ideal for a racetruck, but even a CC can go very fast.
TheBac is offline
post #6 of 13 (permalink) Old 10-21-2007, 05:10 AM
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
I like the point the #2 is around 3 bucks a gallon, Race gas c16 is 14bucks a gallon.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
post #7 of 13 (permalink) Old 10-21-2007, 05:13 AM
that, plus a small block putting out the same performance as a d-max, both with drivetrains to match, the d-max will be more efficient and stronger, more useful, less tempermental, able to have multiple running tunes, last longer, and shoot way past 13's still beating a 13's small block in all the aforementioned areas
plus small blocks don't roll the coal
post #8 of 13 (permalink) Old 10-21-2007, 08:32 AM
Mafia member #105
ripmf666's Avatar
I have almost 20k in my blown sbc and not carring much these days for it,thinking about running a LBZ in my camaro.
She's Alive again
ripmf666 is offline
post #9 of 13 (permalink) Old 10-27-2007, 01:02 AM
Powered By Ford
FordRacing200's Avatar
duramax in a camaro? lol i hate that idea. Keep the black smoke to the 2500 and 3500 trucks :smoke
FordRacing200 is offline
post #10 of 13 (permalink) Old 10-28-2007, 08:07 PM
01duramax6spd's Avatar
Camero's with D-Max's will be the next big thing :Thumbup: . There is already a Chevelle and an Impala,maybe more that I'm overlooking.
01duramax6spd is offline
Closed Thread
