swaping d-max into a ford - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SICKS-O, this thread has received 10 replies and been viewed 1676 times.
post #1 of 11 (permalink) Old 11-26-2007, 02:44 AM Thread Starter
Slow 6.0
i read the thread below this one about the differences between the four series (lb7 lly lbz & lmm), im a little bit more educated in that department but now i need to ask... if i were to swap a dmax into my 99 ford how do i adapt the wiring harnesses to make one with my truck? most of it is straight forward but i was thinking about how the gauges are going to work and how the starter and fuel pump will turn on, is there a swap book out there somewhere? i think i already know the answer to this question but is one series easier to swap in then another?
2006 F350 XLT 4x4
SICKS-O is offline
post #2 of 11 (permalink) Old 11-26-2007, 04:13 AM
Supporting Vendor
Couple ways of doing it, PPE sells a controller that is actually intended for marine use, but will allow 'standalone' operation of the engine.
What trans were you thinking of running? That will also add to the complications.
I think if you've got a pretty complete donor truck, that will help out a lot. As for the gauges, it may be as easy as, well, no it wont, I was thinking you could just hook up signal wires together. I dont think it would be that easy, but having never tried it I dont know.
We did do some preliminary talking with a Ford owner once about swapping in a Dmax, but never come to happen.
Sad as I am to say it, a CR Cummins would be pretty doable, parts are available to install it
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
post #3 of 11 (permalink) Old 11-26-2007, 04:27 AM Thread Starter
Slow 6.0
i was thinking if i were to go threw with it i would buy a wrecked truck from teh salvage auction so id have everyything id need. as far as trannys go id prob just use the allison. its a tough decision
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 11 (permalink) Old 11-26-2007, 04:42 AM
Supporting Vendor
Yeah, lots of options, but sounds like fun
Eric Merchant
Zeeland, MI
1-866-399-7169
post #5 of 11 (permalink) Old 11-28-2007, 11:26 PM
Send a message via AIM to RSieck
Ahh, dont give up yet!! But if you do, do a CR Cummins...please, it would be a mortal sin to put a bowtie in a real truck.
Early 99 F250 4x4 Ext Cab LB, DP Tuner, Intake/4" Straight Pipe
RSieck is offline
post #6 of 11 (permalink) Old 11-28-2007, 11:32 PM
01duramax6spd's Avatar
The D-Max would be cool but AutoWorld has perfected the Cummins commins conversion into Fords. The coolest one I've seen that they did was an 06' F-550 that had a 6.slow and is now a 3rd gen Cummins and a NV5600.
01duramax6spd is offline
post #7 of 11 (permalink) Old 11-28-2007, 11:50 PM
4cstr
Oh...but a D'Max in a Ford would be the cat's meow.
It hasn't been done before...at least to my knowledge...so that alone would make it way cool.
And considering the power they are now getting out of the 6.6L...I think it would be absolute best of both worlds with a 6.6L in a Superduty.
Come'on lottery. If I hit...Eric...you are getting a call.
post #8 of 11 (permalink) Old 11-30-2007, 04:38 AM
TDG Junior Mafia #61
Dieselson's Avatar
That's a new idea, do it, its original. PPE (Pacific Performance Engineering)can put a duramax into just about anything, a ford would be easy for them.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #9 of 11 (permalink) Old 11-30-2007, 05:11 AM
Kip
In the passing lane
Kip's Avatar
Don't do it please don't waste a good truck:
what did the superduty ever do to you to deserve such a thing
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #10 of 11 (permalink) Old 12-05-2007, 03:14 AM
Dieselson's Avatar
Have a piece of crap engine :splat No offense
TDG Mafia
The Diesel Garage
"Can you keep up??
