aftermarket cam?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by foxygoliath, this thread has received 5 replies and been viewed 3058 times.
post #1 of 6 (permalink) Old 03-29-2008, 12:23 PM Thread Starter
aftermarket cam??
Is anyone here running a radical aftermarket cam on their 6.6 rig. I'm interested to know how that worked out. I am planning a major overhaul project this spring so I am toying around with different ideas. I'd like some input on cams big duration and lift.
foxygoliath is offline
post #2 of 6 (permalink) Old 03-29-2008, 02:10 PM
what are u going to do with it pull it? i have one in my truck i drive and it helps out alot
fwdcummins is offline
post #3 of 6 (permalink) Old 03-29-2008, 08:35 PM Thread Starter
The plans are to make it a dedicated 1/4 mile racer, street manners are not a concern. It's rather hard to find head and cam cominations and engine internals for diesels. Websites are vague and only list bolt ons which I have no interest in as yet. I want to to build the engine while it is out and hopefully not have to do it for quite some time. So I need to do it right the first time.
I like big cams they make great power and bring big smiles.:evil: I would prefer to do a head and cam package that way the two compliment each other.
If I could work the rotating assembly so I could cut down on the torque and up the hp would be great too. There is only so much you can detune torque without compromising performance.
By the way thanks for your reply.
post #4 of 6 (permalink) Old 03-31-2008, 04:44 AM
Tire Smoker
bobo's Avatar
Send a message via AIM to bobo Send a message via Yahoo to bobo
The new Extreme cam from TTS is getting some good reviews.
Bobo's Truck Website
Special Thanks to: Huckstorf Diesel, Merchant Automotive, EFILive, Mike L. @ Inglewood Transmission
05 Twin Turbo Duramax
[email protected]+ on #2 only
bobo is offline
post #5 of 6 (permalink) Old 04-08-2008, 05:03 AM
so cal diesel they are the makers of the new 7.1 stroker kit and up to stage three ported sylinder heads really great stuff they also carry camshafts for plain drag racing setups www.socaldiesel.com check them out
jd_craft is offline
post #6 of 6 (permalink) Old 02-16-2010, 08:18 AM
go to adrenalinetruckperformance.com email rob, he built the truck "maxxed out" runs high 9s/low 10s on fuel only, he sells duramax hot rod parts he will have anything you can think of or can point you in the right direction, hope this helps
03 LB7.4x4.White.EFI
Canadian Club member #41
BFXenon.com
Alligatorperformance.com
Duramaxforum.com ---same name
03Dmax90 is offline
