Diesel Truck Forum - TheDieselGarage.com - View Single Post - meter timing cat + others
View Single Post
post #5 of (permalink) Old 05-09-2016, 05:31 AM
theakerstwo
If it has a mag pickup then your ok.The snapon set up I have gets its timing pulse from the injector fuel line and you use a degree tape on the front pulley.That does not tell you your static timing.The snapon light like I have only is good to check your advance curve.
theakerstwo is offline
The Following User Says Thank You to theakerstwo For this addition to TDG:
Oxbow12 (05-13-2016)
