dumb question? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dmanmus, this thread has received 11 replies and been viewed 2018 times.
post #1 of 12 (permalink) Old 05-16-2011, 05:16 AM Thread Starter
dumb question?
what does all this stuff mean and what does it do? CAT delete, ERG delete-i wanna get stacks and a spartan tuner and do a dpf, will that stuff help with the stacks/tuner/dpf? can i do all of them? should i do all of them? would it hurt me/ would it help mpg on an 08 6.4
dmanmus is offline
post #2 of 12 (permalink) Old 05-18-2011, 01:09 AM
Sterling Grey 2010's Avatar
Images: 6
im no expert but to do a tuner you need to delete the dpf
STERLING GREY 2010
Sterling Grey 2010 is offline
post #3 of 12 (permalink) Old 05-18-2011, 01:45 AM
pubs34's Avatar
You don't have to delete the Dpf if you don't want to, Spartan makes tunes that work with the existing system, i ran mine for a few days before i took everything off, it does run better with everything off cause you can then run the bigger tunes.
Spartan Tuned
AFE air box
4" stainless exhaust
2 1/2" lift
Tinted windows
Those nice heated leather seats
Sunroof
custom built charge pipe
pubs34 is offline
post #4 of 12 (permalink) Old 05-19-2011, 11:09 PM
techrescuediver's Avatar
A DPF Delete will remove the diesel particulate filter, this can not be done with a tuner of some sort. Spartan, H&S, SCT, DPF-R. Without a DPF delete there will be no change in exhaust sound, also there will be no black smoke with the dpf on. Some say tuner and dpf delete will help the mpg but not an extreme change. Dpf delete will help in the longevity of the 6.4. I'll post some more links up for more information. Your best bet is to search some the other forums if you cant find it here. Good luck.
2008 CC Lariat F250
S&B CAI/Westin Bull Bar/Nitto Trail Grapplers/Pioneer/In-Dash/DDM HID's
techrescuediver is offline
post #5 of 12 (permalink) Old 05-19-2011, 11:14 PM
Tuners can turn off the egr... what the tune does is the same as unpluging the egr on the 6.0... the valve stays closed and you get more low end power and less boost up top the... the physical block off just improves air flow ...I've heard that an egr delete is cab off procedure but im not 100% sure on that just yet.
2008 CC Lariat F250
post #6 of 12 (permalink) Old 05-20-2011, 02:12 AM
pubs34's Avatar
The Spartan tunes do run with the existing system, it will still go thru regen and run as normal, agin these are the low tunes, yes you can run without the DPF but will eventually with the bigger tunes that shut down the regen, but sooner or later you will plug up the Cat.
Spartan Tuned
AFE air box
2 1/2" lift
Tinted windows
Sunroof
pubs34 is offline
post #7 of 12 (permalink) Old 05-22-2011, 09:55 PM Thread Starter
So do you recomend doing the CAT delete
dmanmus is offline
post #8 of 12 (permalink) Old 05-22-2011, 09:58 PM Thread Starter
And does anyone know what louisiana's laws are regarding the dpf
dmanmus is offline
post #9 of 12 (permalink) Old 05-23-2011, 12:47 AM
Sawed Off's Avatar
I deleted my cat and dpf. Running a H&S minimax tuner and I wish i would of did it sooner!
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
20" predator8 wheels
Toyo AT's
Rip 06 6.0 You were a great truck and will be missed
Sawed Off is offline
post #10 of 12 (permalink) Old 05-23-2011, 03:00 AM
pubs34's Avatar
just my two cents but if you are going to take off one, take them both off, not sure how long it would take to plug the cat if you leave it on but there not cheap.The DPF is suppose to be replaced something like every 125,000 miles, don't think there cheap either. like Sawed Off, just did mine earlier this year and wish i would have done it sooner also. But like I said earlier, if you don't want to take anything off now, Spartan has some low level tunes that run with the existing stock Ford equipement.
Spartan Tuned
AFE air box
2 1/2" lift
Tinted windows
Sunroof
pubs34 is offline
Dumb Question I know Slim_33 5.9L Cummins (2003-2007.5) 13 06-28-2009 05:58 AM
Dumb question? firefighter42 2003-2007 6.0L Power Stroke 20 04-13-2008 12:41 PM
might be a dumb question imported_The Blue Beast 2003-2007 6.0 Tuner Forum 2 08-07-2007 01:44 AM
Dumb Question 03powerstroken 2003-2007 6.0L Power Stroke 10 02-26-2007 07:49 PM
Dumb question... ThorsF350 General Diesel 1 01-10-2006 10:37 PM
