P2452 Diesel Particulate Filter Pressure Sensor A Circuit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TxHammer, this thread has received 2 replies and been viewed 28061 times.
post #1 of 3 (permalink) Old 06-03-2011, 03:12 PM Thread Starter
Anybody have this issue? If so how do you fix it?
TxHammer is offline
post #2 of 3 (permalink) Old 06-06-2011, 11:37 PM
P2452 - Diesel Particulate Filter Pressure Sensor A Circuit
Description: The powertrain control module (PCM) monitors the rationality of the diesel particulate filter pressure sensor during idle and part load operating conditions. The test fails when the diesel particulate filter pressure sensor signal value at idle is less than 0.15 kPa (0.022 psi). The test also fails when the diesel particulate filter pressure sensor signal value at part load is less than a minimum value or greater than a maximum value. These minimum and maximum values are based on the volume of exhaust.
Possible Causes: Diesel particulate filter pressure sensor connecting hose is loose, cracked, or missing
Diesel particulate filter pressure sensor connecting hose port is cracked or broken
Excessive amount of soot or ash in the diesel particulate filter
Damaged diesel particulate filter pressure sensor
wp6529 is offline
post #3 of 3 (permalink) Old 06-14-2011, 04:34 AM
TEXAS FIGHT
Hellraiser's Avatar
could be a bad sensor.
08 F250 Ext. Cab LWB 4x4.
Hellraiser is offline
Cleaning a Diesel Particulate Filter DPF dfuser 2008-2010 6.4L Power Stroke 24 02-14-2012 06:22 AM
Particulate Filter Back Exhaust - any gain? Jeremiah 2008-2010 6.4L Engine Tuner Forum 10 03-20-2010 12:09 AM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 02:54 AM
Fuel Pressure Gauge & IssPro Pyro Circuit Box Cowboy Whats Been Sold 4 03-21-2008 11:15 PM
Particulate filter info 4cstr General Diesel 7 08-08-2006 02:21 AM
