08 f350 Driveabilty problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by joesgirl58, this thread has received 2 replies and been viewed 1243 times.
post #1 of 3 (permalink) Old 06-04-2011, 01:33 PM Thread Starter
Unhappy 08 f350 Driveabilty problem
08 f350 .while driving with cruise on the transmission seems like it shifts down 1 gear and rpm goes to 4000 and the trans cooler gauge goes from middle of gauge to cold and the light around the gear indicator goes away. have to pull over turn off and restart and then will do it again. any ideas?
joesgirl58 is offline
post #2 of 3 (permalink) Old 06-08-2011, 02:56 PM
I would tend to suspect a problem with the transmission control module (TCM) or the connections to it. The TCM is mounted just above the frame next to the transmission on the drivers side, so it's a bit less protected than the rest of the truck's control modules. Have the truck checked for any diagnostic codes, particularly codes stored in the TCM.
wp6529 is offline
The Following User Says Thank You to wp6529 For this addition to TDG:
joesgirl58 (06-14-2011)
post #3 of 3 (permalink) Old 06-14-2011, 09:49 PM Thread Starter
was a rub spot on the wires going the tcm and was causing short. thanx for the help.
04' F350 Driveability Problem! XxApollynxX 2003-2007 6.0L Power Stroke 5 09-11-2009 02:37 PM
89 f350 e4od problem morsemotorsports 7.3L and 6.9 IDI (Pre 1994) 4 08-23-2009 02:03 PM
F350 Downshift problem auto trans wi.threebars 2008-2010 6.4L Power Stroke 0 04-30-2009 11:41 PM
2002 F350 Power Problem shamrock13 1994-2003 7.3L Power Stroke 6 12-24-2007 06:23 AM
96 f350 headlight problem 96 stroker 1994-2003 7.3L Power Stroke 2 11-11-2007 01:21 PM
