2008 F450 Automatic Transmission - Fluid Change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Black06, this thread has received 2 replies and been viewed 7660 times.
post #1 of 3 (permalink) Old 07-31-2011, 10:19 PM Thread Starter
Reached the mileage requirement for transmission service. Hoping that this is something I can do myself. Doing some reading on the topic. Job 3 with internal filter.
1. Is service of the internal filter required at 30,000 miles ?
2. Is this service a drop/fill of the transmission fluid, or a complete dialysis of the trans, cooler, torque converter, etc... ?
2. Any special tools ?
Lessons learned that you can share on the topic.
Thanks in advance
2008 F450 - Pearl Blue with Tan - 4.30 (Job 3)
Spartan 310hp w/TCM, Airaid Drop In Filter, 5" MBRP w/ 6" Tip, 2" level kit, Firestone Air bags in the rear, Bilstein's all around
2010 Open Range 429bhs 5th
http://good-times.webshots.com/album/565591458baIstp
Black06 is offline
post #2 of 3 (permalink) Old 08-01-2011, 05:09 PM
Automatic transmission fluid and filter changes are specified at 60,000 mile intervals. Flushes are not specified.
A heated flush machine is required to flush the transmission, so it is not a DIY operation generally. Since a flush is not specified, you should be able to DIY the fluid and filter change and not worry about the unchanged fluid left in the system unless there is an actual problem and the fluid is contaminated or burned.
wp6529 is offline
The Following User Says Thank You to wp6529 For this addition to TDG:
Black06 (08-01-2011)
post #3 of 3 (permalink) Old 08-01-2011, 06:38 PM Thread Starter
...I like the 60,000 interval better. I now realize that the 30,000 mile recommendation is for the "external mount remote filter". Thanks.
48,000 Km (30,000 Miles)
Change engine oil and install a new oil filter.
Rotate tires and inspect for wear (on vehicles with dual rear wheels, only rotate the tires if unusual wear is noted).
Check the air filter restriction gauge, install a new filter as necessary.
Change automatic transmission fluid on all vehicles equipped with the TorqShift® transmission and externally mounted remote filter.
Install a new remote filter if equipped with a TorqShift® transmission.
Inspect automatic transmission fluid level on all other vehicles (if equipped with an underhood fluid level indicator).
Check and lubricate ball joints (RWD vehicles).
Check and lubricate steering idler arms.
Carry out multi-point inspection (recommended).
Black06 is offline
68RFE Transmission Filters & Fluid Change gsbrockman 6.7L Cummins (2007.5-2011) 18 03-06-2011 06:22 PM
2000 Pontiac Grand Am Automatic Transmission Fluid Filter and Seal Replacement ripmf666 GM Spec Info 0 09-18-2010 12:48 PM
2008-2009 superdutys with automatic transmission and manual tranfercase stroker7.3L444 2008-2010 6.4L Power Stroke 12 01-02-2009 06:02 PM
Manuel Transmission Fluid Change Rusty-Carlton 1994-2003 7.3L Power Stroke 6 04-22-2007 02:33 AM
ZF6 Transmission Fluid Change hhrecovery General Ford Truck and Excursion 3 06-02-2006 06:54 PM
