2008 F350 6.4 Metal Fragments on the Oil Plug - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fasteddie08, this thread has received 1 replies and been viewed 3906 times.
post #1 of 2 (permalink) Old 10-24-2012, 06:17 PM Thread Starter
2008 F350. 6.4, 165,000 miles. Been runnign the same tune since 25,000 miles....change oil every 10,000 without question. Oil plug has alwasy been clean. This tiem the magnetic plug had some shavings on it.....first time it ever happened. I will keep running her and will pull the plug again in 2,000 miles and re-check. Anyone have any ideas? I know the spectrum if possibilities is broad, but any in put would be appreciated. Thanks!
Fasteddie08 is offline
post #2 of 2 (permalink) Old 10-29-2012, 02:31 AM
Describe the type of metal black, silver flakes, or aluminum alloy. If you have the old oil filter cut it apart and looking there as well.
Black, fine is not abnormal unless there is a lot of it, a bulb on the magnet and lots in the filter.
Silver hard thin flakes are cam or follower, problems.
Aluminum alloy is the piston.
Johnp3 is offline
Tags
metal on oil plug, metal shavings, oil
2008 F350 CC/LB SRW HillbillyDeluxe Vehicles For Sale 8 06-17-2010 06:20 AM
2008 f350 8 to 10 lug adapters hotrod360 Ford Parts wanted 0 04-26-2010 11:41 PM
2008 F350 4x4 Dually SB/CC battle cattle Whats Been Sold 6 01-26-2010 12:12 AM
2008 F350 oil leak and fumes in cab. Steve W 2008-2010 6.4L Engine Tuner Forum 2 12-07-2009 01:08 AM
2008 f350 wheels on my 04 6.0 hotshot4819 General Ford Truck and Excursion 5 10-03-2007 04:14 AM
