2 stroke oil in a 6.4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigpete, this thread has received 4 replies and been viewed 2220 times.
post #1 of 5 (permalink) Old 01-14-2013, 01:03 AM Thread Starter
Just wondering if I can run 2 stroke oil as my fuel additive like I did in my 6.0. Truck has a DPF delete on it. I have a few cases of 2 stroke oil left for the 6.0, just not driving it much now that I have the 6.4. Just didn't know since it runs alot higher fuel pressure. Thanks.
bigpete is offline
post #2 of 5 (permalink) Old 01-18-2013, 04:41 PM
The sulfer in the 2 stroke oil will ruin your DOC if you care. If you ever need to put your DPF back on it will not pass emissions should they change the law and require emission checks on diesels where you live.
I have used the Motorcraft cetane booster and injector lube in every tank for my injector pump and injectors. I now use Opti Lube based on this test http://www.jatonkam35s.com/DeuceTech...itive_test.pdf
2008 F450 6.4 diesel dually loaded.
2x6 bulldog is offline
The Following User Says Thank You to 2x6 bulldog For this addition to TDG:
broncobob (01-26-2013)
post #3 of 5 (permalink) Old 01-26-2013, 02:02 AM Thread Starter
Thanks for the link, very good information. Should also add that DOC is also deleted. Makes you think twice about what additives to use. Thanks again.
bigpete is offline
The Following User Says Thank You to bigpete For this addition to TDG:
broncobob (01-27-2013)
post #4 of 5 (permalink) Old 01-31-2013, 02:01 AM
oldnotslow's Avatar
I would caution anyone about making decisions based on this "test". It raises more questions than it answers about lubricity and additives. I don't find any certification regarding the "independent testing laboratory", the methods or the results. One of the highest rated products was purchased directly from the manufacturer and it was "experimental".
oldnotslow is offline
The Following 2 Users Say Thank You to oldnotslow For this addition to TDG:
Oxbow12 (02-17-2013), Weld engineer (01-31-2013)
post #5 of 5 (permalink) Old 01-31-2013, 03:00 AM
Weld engineer's Avatar
I tried optilube based on this testing and didn't see anything different in my 6.0. It looks, smells and probably tastes just like power service product. I use Archoil 6200 and do see a difference. (Not in the group tested).
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
2 stroke oil? JIMS 03 73 General GM Truck Forum 10 12-04-2009 02:20 AM
2 stroke oil 03lariatsd 2003-2007 6.0L Power Stroke 59 07-16-2009 06:45 AM
2 stroke oil use.... mpdxtreme 1994-2003 7.3L Power Stroke 33 02-26-2008 03:06 PM
2 stroke oil BriteWhiteRam 5.9L Cummins (2003-2007.5) 46 02-16-2008 11:46 PM
2 stroke oil Kip 1994-2003 7.3L Power Stroke 94 08-25-2007 01:45 AM
