white smoke @idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Dave 04, this thread has received 12 replies and been viewed 2391 times.
post #1 of 13 (permalink) Old 08-13-2013, 02:20 PM Thread Starter
Diesel Dave 04's Avatar
white smoke @idle
08 110K on the clock has H&S mini Max runs great But smokes white at Idle.
Any input? bad injector?
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #2 of 13 (permalink) Old 08-14-2013, 01:16 PM Thread Starter
no one has any input?
post #3 of 13 (permalink) Old 08-15-2013, 06:36 AM
pyro2nite's Avatar
My guess would be coolant. Hope I'm wrong
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #4 of 13 (permalink) Old 08-19-2013, 01:34 PM
Cmon problem on these is the EGR coolers start to leak. If it is white smoke, it would be either coming from those, or possibly a head gasket. If you don't have to do emissions, I would spend the $125 and get an EGR delete kit and see if it goes a way then. Also, to u can turn off the EGR with your tuner to see if that has any affect.
Sent from my Galaxy Nexus
diode_ee is offline
post #5 of 13 (permalink) Old 08-19-2013, 05:04 PM
pyro2nite's Avatar
Turning off the EGR via a turner, will not prevent coolant from entering the cylinders. It will only shut off the recirculated exhaust.
post #6 of 13 (permalink) Old 08-19-2013, 05:57 PM
Aimless Wanderer
Is this a steady stream of white smoke or puffs? Steady would indicate coolant, where puffs would be more likely an injector(s) failing. Also white smoke that does not exist under loading can point to injectors, or a minor coolant leak internally. What does the exhaust "smell" like? Does it have a sweet aroma, or oily? I don't condone sniffing the exhaust, but it's a good indicator.
Backslap is offline
post #7 of 13 (permalink) Old 08-19-2013, 06:37 PM Thread Starter
I have not seen the truck yet But he tells me it is white/ blue and it goes away just off idle. Im thinking it is going to be a bad injector but Im not sure and im not sure hoe to tell what one if it is a bad one.
post #8 of 13 (permalink) Old 08-19-2013, 07:16 PM
Aimless Wanderer
I like the sniff test to the exhaust as it will tell you a lot......
If suspect to be an injector, have them all rebuilt or exchanged. They wear together and replacing one on a engine with mileage just invites the others to give problems. I've seen one or two injectors replaced in an engine and it then misfire due to imbalance of fuel delivery.
Backslap is offline
post #9 of 13 (permalink) Old 08-26-2013, 01:35 AM
pyro2nite's Avatar
That is not necessary true. When the regen process starts, it will use number 8 and 7 injector, thus there is more use on the two.
post #10 of 13 (permalink) Old 09-02-2013, 10:55 AM
you are right !
Montysmith is offline
White smoke @ idle Shef 2003-2007 6.0L Power Stroke 5 11-08-2010 11:56 AM
White smoke, rough idle, SOMETIMES... superpstroker 1994-2003 7.3L Power Stroke 2 10-12-2007 02:09 PM
white smoke off idle when cold mxchase 2003-2007 6.0L Power Stroke 2 09-23-2007 09:34 PM
White Smoke At Idle mxracer74 Duramax 2001-2004 (LB7) 7 08-16-2007 01:26 PM
white smoke and poor idle doob51 5.9L Cummins 12 Valve (1994-1998.5) 2 01-14-2007 07:50 AM
