4 wheel drive system not operating - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 09F350KingRanch, this thread has received 6 replies and been viewed 1374 times.
post #1 of 7 (permalink) Old 12-30-2013, 02:07 AM Thread Starter
09F350KingRanch's Avatar
I had to get my PCM reset couple of weeks ago and this morning I wanted to use the 4 wheel drive for the 1st time since the reset and it didn't engage in 4H or 4L. Would loading the PCM incorrectly effect the 4 wheel drive system operating correctly or is it possibly another issue?
09F350KingRanch is offline
post #2 of 7 (permalink) Old 12-30-2013, 03:06 AM Thread Starter
hmm
I just went out to look over the system, I rotated the hubs and now it works. Could it be possible water maybe in the system and since last night got in the SINGLE Digits it cause the problem? If there might be water in the system how would I go about removing the water?
post #3 of 7 (permalink) Old 12-31-2013, 02:53 AM
Weld engineer's Avatar
so 4WD works when you turn them to lock correct? When they are in in Auto they are vacuum actuated so either a vacuum leak or the vacuum pump isn't working. I wouldn't think it is tied to the PCM but I don't know much about the 08 to 10 trucks. The ESOF electronic shift on the fly works pretty much the same on ford trucks. If they turned thats a good sign they are not frozen up.
the biggest problem seems to be not cycling them often (say 1-2 times a month) and turning them manually into lock. The ones on my 04 were frozen so I opted to replace them with WARNS solely due to price.
Hopefully someone with more experience responds.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #4 of 7 (permalink) Old 01-25-2014, 07:29 PM
I had the same problem with my 08.$%^& truck got stuck on frozen dirt! I took it to Ford and they told me one of the vacuum lines came off! I asked how that could happen and they gave me some story about how I could have run over something on the road ...BS...I had recently had the truck in for maintenance including tire rotation And they charged me $108 labor! short answer: look under the truck and make sure the vacuum lines are attached ... BEFORE you take it to the dealer!
yukondiesel is offline
post #5 of 7 (permalink) Old 01-28-2014, 06:37 PM Thread Starter
Yea but what's weird with mine is it doesn't function the 1st time, but I can turn the truck of and then back on and then it will switch into 4H or 4L.
2009 F350 King Ranch 6.4 C/C Longbed, 355/60r20" Toyo, 6" Skyjacker Lift, Bully Dog GT Tuner, Leer 700 Tonneau Cover, Bedliner Carpet.
post #6 of 7 (permalink) Old 01-28-2014, 09:13 PM
Aimless Wanderer
You quite possibly have a bad actuator switch either where you interact, or the solenoid valve(s) that route vacuum to the servos to engage the 4X4. Cold weather brings these little problems to the surface as the switchgear ages and, (in a lot of cases) the assembly grease dries/hardens.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
post #7 of 7 (permalink) Old 01-28-2014, 11:16 PM Thread Starter
So would you all say this is a EASY DIY?
4 Wheel drive MoBe88 2003-2007 6.0L Power Stroke 3 09-09-2011 01:58 PM
4 wheel drive help POWER STROKE 99 1994-2003 7.3L Power Stroke 8 12-08-2007 02:46 AM
4 wheel drive AllOut0606 1994-2003 7.3L Power Stroke 20 10-30-2007 02:40 AM
4 Wheel Drive Help BillsFan 1994-2003 7.3L Power Stroke 6 09-16-2007 02:18 PM
4 wheel drive!!! Big Bad Stroker 1994-2003 7.3L Power Stroke 10 03-09-2007 02:07 AM
