Is this 6.4 worth getting into?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coachhim, this thread has received 2 replies and been viewed 1866 times.
post #1 of 3 (permalink) Old 06-24-2015, 03:45 PM Thread Starter
OASIS RESULT: 1FTWW31R88EA23239USA: EN-US23-JUNE-2015 / 21:02:35 EST/ EDCAS041B
Local Time: 23-JUNE-2015 / 9:02:34 PM
VEHICLE INFORMATION
Additional Information
VEHICLE DESCRIPTION: 2008 F-SERIES Version/Series: 350 SERIESPAINT COLOR: Dark Blue Pearl W/B
BODY STYLE: DOUBLE CAB (CREW CAB)Drive Type: 4 WHL L/H PART TIME DRIVEPAINT CODE: DX
ENGINE: 6.4L Diesel V8 Twin TurboAXLE RATIO: 3.73 RatioGROSS VEHICLE WEIGHT: 11,500 LB. GVW
ENGINE CALIBRATION: 8F716A0AAXLE CODE: 3LRADIO: With AM/FM CD Player
TRANSMISSION: 5 Speed Auto 5R110W - HI/TorqueWHEEL SIZE: 8 X 20" Prem Forged Pnt Alum Wheel
TIRE: LT275/65R 20E A/T OWL Tire
WARNING MESSAGES
ACCURATE REPAIR NOTIFICATIONS
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO TSB 09-08-05
FOR DTC P040D SEE TSB 11-06-15
FOR RADIATOR COOLANT LEAKS SEE TSB 11-12-04
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 25-APRIL-2007BUILD DATE: 05-FEBRUARY-2007Release Date: 06-FEBRUARY-2007
SALE MILEAGE: 00037
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
| Report a Vehicle Concern | On-line 1878 |
END OF OASIS REPORT FOR 1FTWW31R88EA23239
VIN1FTWW31R88EA23239
Vehicle LineT/F7Market Derived CodeF
Body CabT/BCVer. SeriesT/CD
Drive TypeT/E
PLT CDA1TRS CDT/BEENG CDT/QL
Production Date05-FEB-07Warranty Start Date25-APR-07
Selling Dealer171151Selling CountryUSA
AWS Claim KeyTrx CodeTime In ServiceLabor HoursDealershipDIST (Miles)Repair DatePrefixBaseSuffixDoc
Details916307S490.5HEMBORG FORD3723-MAR-07***08986041
Customer CommentsPERFORM RECALL 07S49
Tech CommentsRECALL PERFORMED
Details445360299KEN GRODY FORD1132003-JAN-088C3Z9A332B08786952
Customer CommentsDIAGNOSE OIL LEAK FROM ENGINE AREA
Tech CommentsCHECK FOR LEAKS, LEAK AT LEFT SIDE NEAR CYL HEAD, REPL FUEL LINE LEFT SIDE, RETEST
Details445359292.7KEN GRODY FORD1132003-JAN-088C3Z8009B08786951
Customer CommentsDIAGNOSE COOLANT LEAK FROM ENGINE AREA
Tech CommentsPRESSURE TEST AND REPLACE FAILED RADIATOR
Details322125290KEN GRODY FORD1132004-JAN-08*3863100*08802151
Customer CommentsTHE SEAM ON THE LEFT SEAT IS SPLIT
Tech CommentsSUBLET FOR REPAIR ON SPLIT SEAMS
Details176293608C0117.3KEN GRODY FORD2275610-SEP-08***00716840
Customer Comments08C01 DEMONSTRATION DELIVERY HOLD PERFORM PRIOR TO VEHICLE DELIVERY
Tech CommentsRECALL SEAT BACK INSPECTION AND REPAIR
Details1801198E84174.2KEN GRODY FORD2275610-SEP-088C3Z8009B00716851
Customer CommentsTHERE IS A COOLANT LEAK
Tech CommentsREPLACE LEAKING RADIATOR AND POUROUS COOLANT TUBES, PROCEDE WITH ADDITIONAL REPAIRS ON LINE 52, CHECK ENGINE LIGHT ON, WHITE SMOKE FROM EXHAUST
Details1824237S071728.2KEN GRODY FORD2275610-SEP-088C3Z6049BB00716852
Customer CommentsCHECK ENGINE LIGHT ON, WHITE SMOKE FROM EXHAUST
Tech CommentsSELF TEST P0297, VERIFY CONCERN, REMOVE BOTH EGR COOLERS TO TEST WITH BLOCK OFF TOOLS, FOUND BOTH LEAKING AND REPLACE, PRESSURE TEST AT 26PSI, COOLING FAN WORKING EOT AT 208F, ECT AT 201F, REMOVE CAB TO REMOVE CYLINDER HEADS SUBOUT FOR MAGNAFLUX, CRACKED AT CYL 3,5,7,6,8, REPL BOTH CYL HEADS, M TIME TO REPLACE LEAKING FUEL RAIL PRESSURE SENSOR, REINSTALL CAB AND ROAD TEST, COOLING SYS PRESS NOW AT
Details2066235E8320.3DOWNEY FORD2464524-NOV-086E5Z13466AC02722301
Customer CommentsRIGHT TURN SIGNAL FLASHES TOO FAST
Tech CommentsR&R RIGHT BRAKE LAMP ASSEMBLY AND REPLACED BULB RETESTE OK
Details3937291S07263.7KEN GRODY FORD3431409-JUN-098U7Z12A650CD02551151
Customer CommentsTHE TRUCK HAS NO POWER DOES NOT GO OVER 40 MPH
Tech CommentsF.S.E NICK WALTER INVOLVED IN REPAIR, PERFORM DIESEL DIAG, PIN POINT TEST, REPLACE EGR TEMP SENSOR, DTC P0400 STILL PRESENT, PIN POINT TEST WIRING, REPLACE PCM, CLEAR DTC, RETEST WITH F.S.E
Details3732809E84267.1KEN GRODY FORD3431409-JUN-093C3Z6D083AA02551152
Customer CommentsTHERE IS AN OIL LEAK (UNDER THE TRUCK BY THE TRANS)
Tech CommentsFAILED SEAL ,ENGINE OIL LEAKS DIAGNOSIS, INSPECT FOUND LEAK AT REAR COVER GASKET, REPLACE FAILED GASKET, CLEAN AREA, RETEST
Details494404308B0633.3KIEFFE & SONS FORD4179415-DEC-09***07402802
Customer CommentsCUSTOMER REQUESTS CUSTOMER SATISFACTION PROGRAM 08B06, COOLING SYSTEM VENTURI TEE INSTALLATION.
Tech CommentsINSTALL A VENTURI TEE KIT INTO THE DEGAS BOTTLE AND RADIATOR VENT HOSES. 08B06B 0.3
Details497889308B06332.3KIEFFE & SONS FORD4179415-DEC-09***07402803
Customer CommentsCUSTOMER STATES COOLANT LEAKING ON GROUND.
Tech CommentsRADIATOR LEAKING AT SEAM, RELATED DAMAGE SEE LINE 2 FSA 08B06 REPLACE RADIATOR ASSEMBLY AND REFILL.
Details494404408B0733.5KIEFFE & SONS FORD4179415-DEC-09***07402801
Customer CommentsCUSTOMER REQUESTS SATISFACTION PROGRAM# 08B07, REPROGRAM POWER CONTROL MODULE AND INSTRUMENT CLUSTER.
Tech CommentsREPROGRAM PCM, TCM AND IC USING IDS RELEASE 57.6 AUTOMATIC TRANS, 08B07B 0.5
Details5246492E72332.6KIEFFE & SONS FORD4239604-JAN-108C3Z8590A07431601
Customer CommentsCUSTOMER STATES FUEL LEAKING UNDER ENGINE.
Tech CommentsCHECK AND FOUND COOLANT LEAKING. PRESSURE TEST SYSTEM AND REPLACE LEAKING O RINGS. RECHECK OK.
Details803708411B2354.5FRITTS FORD6625113-SEP-11***00819640
Customer Comments11B23 POWERTRAIN CONTROL MODULE RECALIBRATION
Tech CommentsRECALIBRATED PCM, TCM AND IC PER RECALL
coachhim is offline
post #2 of 3 (permalink) Old 06-24-2015, 03:54 PM
Old Fart
dbennett48's Avatar
I don't like the history. Look for a better truck or another year with the 6.7 litre engine.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 3 (permalink) Old 06-24-2015, 04:11 PM Thread Starter
Seems like an awful lot has been done to the truck. Definitely would have to have an extended warranty
coachhim is offline
What's DP F-6 worth? ParkerFly Whats Been Sold 5 05-09-2009 12:19 PM
What`s a 5.9 worth? banyon 5.9L Cummins (1998.5-2002) 7 03-06-2009 03:47 AM
what do you think it's worth? jmccall 1994-2003 7.3L Power Stroke 3 12-21-2007 03:47 AM
F.A.S.S is it worth it? dslrunner86 2003-2007 6.0L Power Stroke 6 04-04-2007 02:21 AM
Help! What's It Worth? NateJFH General Ford Truck and Excursion 11 03-28-2007 08:04 PM
