Killing the DPF - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Pourinthecoal, this thread has received 14 replies and been viewed 1461 times.
post #1 of 15 (permalink) Old 03-04-2007, 06:57 PM Thread Starter
Strokin'
Killing the DPF
An Idea:
All we have to do is gut the DFP compeltely, make it straight through, and keep it on the truck. It's 4" at point anyways. Also, gut the kitty if need be and just run a 4" DPF-back system and you're legal wherever you go. If it is gutted, theoretically it should not clog up, thereby not triggering the sensors to regenerate, thus saving lots of fuel, money, and headaches!
Anyone see a problem to this idea?
Cummins, Duramaxes, and Powerstrokes - some of each
Newest: 08 King Ranch - 8" Rize, 20" Monsters, 5" straight pipe, Spartan, Alien Patrol, etc.
Pourinthecoal is offline
post #2 of 15 (permalink) Old 03-04-2007, 07:37 PM
Chitowns Biggest Baller
6.4lkid's Avatar
I dont think that you could gut them and not have the sensors start throwing codes.
Formerly 6.0lkid
2008 F250 FX4 Loaded
SCT TUNED
6.4lkid is offline
post #3 of 15 (permalink) Old 03-04-2007, 08:07 PM
Super Moderator
John_G's Avatar
By "problem" do you mean except that it is COMPLETELY ILLEGAL?
Yes, the PCMs are smarter than that, and even IF you don't get a code, they will know.
I vote for LIBERTY!
John_G is offline
post #4 of 15 (permalink) Old 03-04-2007, 10:15 PM
TDG MAFIA MEMBER #85
onebadf150's Avatar
give it time someone will figure it out, come on the trucks just hit the road !! think about it the 6.0L just started to get good aftermarket parts and they have been on the road since 03.
onebadf150 is offline
post #5 of 15 (permalink) Old 03-04-2007, 11:04 PM
So are you telling us that the pcm is "Big Brother" Moreover, who is going to come arrest you for hot-rodding your diesel????
Fast_Ashley is offline
post #6 of 15 (permalink) Old 03-05-2007, 01:39 AM
I do all my own stunts
Send a message via MSN to kblackav8or
As long as you aren't in a draconian state you will probably be alright. Your warrantee may be toast though. As long as you aren't making alot of smoke you probably won't even be noticed.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #7 of 15 (permalink) Old 03-05-2007, 04:23 AM
Seriously, wheres the fun in that? It will only be a matter of time untill someone crackes the code to write that segment out of the pcm. If you own one and you truely want to try fooling the sensors let me know. I want to see if the method I know for a fact to work on another manufacturer will work on the Fords.
Bone
2008 F350 Crew Cab long bed Lariat 4x4 6.4 Powerstroke. 4.5" CST lift 35x12.50R18 Toyo M/T's
SCT Tuned by ME. 529.6 RWHP 1100.7 LbFt uncorrected on a Load Dyno
efoster_01 is offline
post #8 of 15 (permalink) Old 03-05-2007, 04:33 AM
SmokinCAT's Avatar
If it gets bad enough they will probably start fineing for tampering with a motor that was deemed legal. I have attached a page out of an old service manual, it is for semis but the nature of it fits this topic, also judgeing by the date I would say it would be safe to just multiply the fine.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #9 of 15 (permalink) Old 03-05-2007, 01:59 PM
I wrote in a couple of threads about dropping the 6.4 into the 6.0 body. Would this definately eliminate the DPF? I know you will not have the all new style truck but you can see what the 6.4 really can do without worrying about legal matters, I think it will not have to meet the 2008 emissions if it's under the hood of a 6.0 truck.
2006 Dark Copper/Arizona Beige F-250 4x4 King Ranch CC SB 6.0/TorqShift 3.73LS Build 09/05:Bought 09/05 w/3 miles(12-15-06 9,300 all stock miles)
1993 Mack RW713 Superliner E7-350 Jacobbs Jake 8LL 20/58 Camelback 12R 24.5 Tandem Dump(12-15-06 586,000 miles)
1989 Mack RW713 Superliner E6-350 Dynatard 12sp 20/58 Camelback 11R 24 Tandem Dump(12-15-06 317,000 miles)
1996 Cat 416B 4X4 Ext-hoe (12-15-06 6,200 hrs)
2006copperPSD is offline
post #10 of 15 (permalink) Old 03-05-2007, 02:14 PM
thats a lot of money to be playing with.
KERR is offline
