19.5" wheels - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KERR, this thread has received 8 replies and been viewed 1160 times.
post #1 of 9 (permalink) Old 03-14-2007, 02:42 PM Thread Starter
19.5" wheels
I was wondering where to look for wheels. The Alco's are beautiful that come on the F450's but im not a pollished / chrome guy. So i was wondering if anyone made a more tough looking wheels that can be powercoated or painted. The thought of the factory ones in the mud makes me kida sick.
Also where do you look for tires. I looked on tire rack and they have nothing for a 19.5' wheel
KERR is offline
post #2 of 9 (permalink) Old 03-14-2007, 07:37 PM
The tires on the F450 are truck tires. You need to find a commercial tires store in your area. Steel wheel are gray painted or white or black powder coated. Other colors can be done at a local powder coat place, you buy the gray wheels and get them done. Colored wheels can look good with some chrome lug nut covers.
sacgmc is offline
post #3 of 9 (permalink) Old 03-14-2007, 07:43 PM
For 19.5 wheels check here. http://www.brentzwheels.com/
Get ready to lay down some coin though.
heinzboy is offline
post #4 of 9 (permalink) Old 03-14-2007, 08:42 PM Thread Starter
thanks
Hutichenindustries makes beads lock wheels... they said $1,400 a wheel!
KERR is offline
post #5 of 9 (permalink) Old 03-15-2007, 11:28 AM
what does not kill you ..
Also try Rickson http://www.ricksontruck.com/
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #6 of 9 (permalink) Old 03-17-2007, 04:49 AM
Powered By Ford
FordRacing200's Avatar
just have the stock alcoas powdercoated.
FordRacing200 is offline
post #7 of 9 (permalink) Old 03-17-2007, 05:26 AM
I second the powdercoating of the aluminum wheels!
Fast_Ashley is offline
post #8 of 9 (permalink) Old 03-17-2007, 03:38 PM
You powder coat steel wheels. The temperature of powder coating process is to high (400 degrees) to safely do on aluminum. Also steel wheels are much sturdier for off road applications.
sacgmc is offline
post #9 of 9 (permalink) Old 03-17-2007, 04:23 PM
My wheels are holding up flawlessly. Even with 14,000 pounds behind the truck. Powdercoating doesn't weaken aluminum.
