Fitting topper with tailgate step - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Boulder GT3, this thread has received 10 replies and been viewed 1421 times.
post #1 of 11 (permalink) Old 03-18-2007, 06:09 PM Thread Starter
Be aware that you might have a problem putting a pre-08 topper on an '08 with the tailgate step. Because the bed dimensions are the same most application guides list the topper as the same before and '08. However, I ran into an issue putting my SnugTop on. The bed is fine it's the extra width of the tailgate with the step. It will not let the rear close as the flange on the topper that overhangs the tailgate hits the tailgate step. The window sticks out about 2". I can cut a relief in the lip or I'm sure there will be a new window or flange/lip available to let the rear window close.
Just a heads up and an extra question to ask if you're mounting a topper.
Boulder GT3 is offline
post #2 of 11 (permalink) Old 03-18-2007, 08:30 PM
That was one of the first things I thought of when I saw the tail gate step. It overhangs the tail gate, which will make it tricky to put on toppers and 1 piece toneau covers.
TrailerTrash is offline
post #3 of 11 (permalink) Old 03-18-2007, 08:56 PM
Mafia member #6
Rutcutter's Avatar
Thanks for the tip GT3 :Thumbup:
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #4 of 11 (permalink) Old 03-18-2007, 11:09 PM
Powered By Ford
FordRacing200's Avatar
its also going to make it a PITRA to do a spray-in bed liner.
FordRacing200 is offline
post #5 of 11 (permalink) Old 03-19-2007, 01:23 AM
thats one of the reasons that im going with the retrax bed cover.
2008fx4 is offline
post #6 of 11 (permalink) Old 03-19-2007, 10:53 AM
WHY a prob with spraying the liner?? dont get it. but thanks for the info.Im getting one sprayed in today. what should i look for that they can screw up?? thanks.
imported_QUICK83 is offline
post #7 of 11 (permalink) Old 03-19-2007, 11:12 AM
you just get everything but the tailgate sprayed.
2008fx4 is offline
post #8 of 11 (permalink) Old 03-19-2007, 11:30 AM
THANKS buddy, ill call them today and tell them not to bother with the tailgate (if they were gonna do it), now that you said that, i think the whole thing is plastic anyways.
post #9 of 11 (permalink) Old 03-19-2007, 11:54 AM
Make sure they pop the bed bolts out.
Fast_Ashley is offline
post #10 of 11 (permalink) Old 03-19-2007, 12:43 PM
what do u mean by bed bolts (the bolts that hold in the bed??)and why???? so they are exposed if ever have to take off bed?? thanks
