6.4 Bad Fuel Milage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by duckbill, this thread has received 8 replies and been viewed 1571 times.
post #1 of 9 (permalink) Old 03-20-2007, 06:52 PM Thread Starter
Exclamation 6.4 Bad Fuel Milage
Don't know why everyone is crying about the fuel milage. Oh and its not going to increase 10mpg after breakin. Here is why:
First, go educate yourself about BSFC (break specific fuel consumption) on a diesel.
2nd- displacement. The more volume in the cylinders, the more fuel/air it requires for the same rpm.
3rd-Every body thinks the twin turbo is cool.......spools quicker right! that equals more air which requires more fuel- sooner.
4th- HP, takes fuel to make power, more power=more fuel (see number 1) Thats why everybody has to put bigger fuel pumps on when they start doing the high hp mods.
ReGen- wastes fuel
4.30/4.88 gears-aren't conducive to any thing but pulling. Unless some makes a trans with a quadrupple overdrive, milage WILL suck.
Moral of the story-if you can't afford the fuel bill, don't buy the truck. On average the 6.4 WILL NOT get better milage than a 6.0 in the same truck with the same final drive ratio. A 6.7 Cummins won't be better than a 5.9. The 05/06 cummins (325/610) IS less than an 03/04 (305/555) See number 4
duckbill is offline
post #2 of 9 (permalink) Old 03-21-2007, 12:16 AM
not to ask a dumb question hear. But wouldn't it seem that you should be able to get very similar mileage with (ex. 325hp as the 305hp) version as long as you keep your foot out of it? Yes i know it takes more fuel to make that extra hp but shouldn't fuel comsumption be about the same if you don't use that extra hp?
07 Dodge 5.9 3500 DRW 4x4 QC 6spd:93C_peelo With a few mods.
catdude is offline
post #3 of 9 (permalink) Old 03-21-2007, 12:38 AM Thread Starter
If the programing on the higher hp motor was tuned to make the same or less hp/tq at cruise rpm or any same rpm minus the difference in volume..But as most diesels are programed to have power come on sooner (low rpm/high torque) not likely. Take a look at the hp/tq curves on the engines and then compare the fuel consumption on both and you shall see.
Because the engines are capable of so much power beyond stock, they should develop an inline 4 or 5 cylinder around 3 liter at 200hp and put it in a half ton. It would get over 30mpg
duckbill is offline
post #4 of 9 (permalink) Old 03-21-2007, 01:13 AM Thread Starter
http://marine.cummins.com/attachment...6B/fr91260.pdf
http://marine.cummins.com/attachment...6B/fr90208.pdf
Here are the charts, both for a 5.9 cummins 355 vs 315 hp even at idle, the higher hp uses more fuel.
duckbill is offline
post #5 of 9 (permalink) Old 03-21-2007, 02:12 AM
Good post to set expectations. I am surprised that my 6.4 is returning almost the same mileage as the 6.0. To your point about the available power under the curve; that is why the truck holds the gear when it's on an incline so much longer. No mystery though, more power equals more fuel/energy used.
The more I drive the 6.4 the more I like it. It's worth 1 or 2 MPG vs. a 6.0.
Boulder GT3 is offline
post #6 of 9 (permalink) Old 03-21-2007, 09:22 PM
Whats the deal my truck only holds 23.5 gallons. The two times I filled up with under 15mi till empty I have not filled over 23.5 gal. The window sticker claim the truck has a 30.5gal. tank. I need more than a 300mi range.:shrug:
Rainman is offline
post #7 of 9 (permalink) Old 03-22-2007, 12:12 AM
Are you filling it up yourself or is it at a full service station. The pump will shut off when it senses the foam come up to the neck. If you do it yourself, once the auto nozzle stops let the foam settle a little and run the fuel nozzle slow to prevent too much foam built up. I usually get about 5-6 more gallons after it shuts off automatically.
2006 Dark Copper/Arizona Beige F-250 4x4 King Ranch CC SB 6.0/TorqShift 3.73LS Build 09/05:Bought 09/05 w/3 miles(12-15-06 9,300 all stock miles)
1993 Mack RW713 Superliner E7-350 Jacobbs Jake 8LL 20/58 Camelback 12R 24.5 Tandem Dump(12-15-06 586,000 miles)
1989 Mack RW713 Superliner E6-350 Dynatard 12sp 20/58 Camelback 11R 24 Tandem Dump(12-15-06 317,000 miles)
1996 Cat 416B 4X4 Ext-hoe (12-15-06 6,200 hrs)
2006copperPSD is offline
post #8 of 9 (permalink) Old 03-22-2007, 01:00 AM
'Ol Builder guy
Duke's Avatar
ReGen- wastes fuel
I would have bought one of the new 6.4's if they would have done the smart thing and introduced a 6 speed TQshift with it this year. IMO, it's the bare minimum for the 6.4L. A 7 speed manual would have been an improvement over the ZF6, too. That was dumb on Ford's part, they need another O/D gear. Couple that 5 speed auot with an unproven (in the real world) diesel and I just couldn't do it. I hope it all works out for Ford!
Duke is offline
post #9 of 9 (permalink) Old 03-22-2007, 01:11 AM
I would've considered a 7speed:Thumbup:
over29 is offline
