New problems Fires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Duke, this thread has received 108 replies and been viewed 7034 times.
post #1 of 109 (permalink) Old 03-21-2007, 07:38 PM Thread Starter
'Ol Builder guy
Duke's Avatar
First 6.4L safety recall/reflash 07S49
Guys,
I got this from my inside source. If you have a 6.4L, for safety's sake get over to your dealer right away. You need your first reflash. Don't want to see anyone get burned.
Read here:
http://www.motorcraftservice.com/pub.../12/R07S49.PDF
Duke is offline
post #2 of 109 (permalink) Old 03-21-2007, 07:58 PM
Diesel Enthusiast
It is always great when the recall states it is to prevent flames......
2002 F250 Extended cab XLT 4X4 long bed.
Intake, muffler delete, DP-Tuner
1997 F250 Regular cab 5 speed 4x4.
3in Downpipe, Stage 1 sticks, solid flywheel conversion, 6 position chip. Work truck.
5gear is offline
post #3 of 109 (permalink) Old 03-21-2007, 08:22 PM
I was looking forward to having flames shooting out of the tail pipe. I knew I should have gotten 1 early.
TrailerTrash is offline
post #4 of 109 (permalink) Old 03-21-2007, 08:59 PM
That's too bad, they could have marketed that as an "add-on" and charge extra for it...
Sam
The Trash Truck
96 CC F350 SRW - Built for SVO and mileage
Go Green - HotFox, Dual Heated Dahl 100s, Fuel Filter Coolant Wrap, ArcticFox
Go Fast - Hybrids, H2E, 6.0 IC, Fuelab, BTS 144.2/291.5 uncorrected
thanx go to
Rockin-S-Performance - Install, tech support, and advice
Diesel Innovations - Killer Deal on Parts
Tony Wildman/SWAMPS - Tuning
genie144 is offline
post #5 of 109 (permalink) Old 03-21-2007, 10:23 PM
New problems Fires
best to see whole article here is part
WASHINGTON -- Ford Motor Co. today told dealers to temporarily stop selling certain 2008 F-series Super Duty diesel pickups after receiving reports of flames shooting out of the vehicle's tailpipe.
Ford said it was recalling 37,400 F-Series Super Duty trucks with 6.4-liter diesel engines. The majority of the pickups _ 29,000 _ were still on dealer lots, the automaker said.
Ford spokesman Dan Jarvis said it received three reports of flames coming from the truck's tailpipe, caused by leaking fuel that ignited in the exhaust system's diesel particulate filter near the tailpipe, caused by leaking fuel that ignited in the exhaust system's diesel particulate filter near the tailpipe.
.....Jarvis said the flames could only occur in engines with leaking fluids, which he said was very rare. Two of the complaints involved leaking fuel injectors and the other involved leaks coming from a crack in the turbocharger shaft.
The automaker will have dealers upgrade software for the powertrain control module, which will power down the engine under higher-than-expected temperatures in the diesel particulate filter. Similar software updates will take place at the Louisville, Ky., plant where the trucks are built.
Jarvis said the stop sale order should only last a few days as dealers reprogram the software. Owners of the remaining 8,400 trucks will be notified about the recall in early April and will be able to have the software upgrade at no charge.
In a separate action, fewer than 10,000 of the trucks will have the battery cable rerouted to avoid chafing against a shield in the engine compartment that prevents water and mud from getting into the engine.
Ford said the recall does not affect gasoline-powered pickups or those with 6.0-liter or 7.3-liter diesel engines.
link
http://www.detnews.com/apps/pbcs.dll...450/1148/rss25
2007 GMC Sierra Classic 3500 Crew Cab dually 4X4 SLT
d67rdave is offline
post #6 of 109 (permalink) Old 03-21-2007, 10:32 PM
Maybe they could throw in a pack of marshmallow's, graham crackers a hershey bar and a stick!!!!!! or some weeeeeneeeees.
2007 White and tan F-250 CC Lariat 6.0L FX4 :93C_peelo
2003 Gray F-250 CC XLT 6.0L FX4=reaquired by Ford
jmcholden is offline
post #7 of 109 (permalink) Old 03-21-2007, 11:30 PM
Fire! Fire! Fire!
Mikeyjustrocks is offline
post #8 of 109 (permalink) Old 03-21-2007, 11:44 PM
Never Listen to a Monkey!
Send a message via AIM to CBRJohn2000 Send a message via MSN to CBRJohn2000 Send a message via Yahoo to CBRJohn2000
I thought it was an accessory??
John
2005 Dark Blue Metalic 2500HD LT CC/LB 2wd w Dual Alternators, RSEC, 06 Towing Mirrors, Snug Top Bed Cover,Edge Juice/Attitude, F/S, B/P, B/S, TxC CAI, TxC V2 w/fan, Mike L. Trans. Cooler, Suncoast 6spd Conversion Kit, Factory Style Lighted Running Boards, Tekonsha Sentinel 9055 Brake Controller. Michelin 265/75r16 LTX M/S tires. ......... Born On 02/05
2001 Saturn L200 (Wifes Daily Driver)
1977 Ideal Travel Trailer 7K+
1978 Wreidt Boat w/Berkley Jet SB 350
CBRJohn2000 is offline
post #9 of 109 (permalink) Old 03-21-2007, 11:53 PM
Mafia member #6
Rutcutter's Avatar
I still haven't seen the flames from mine. :shrug:
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #10 of 109 (permalink) Old 03-21-2007, 11:59 PM
glad for that .Still wanting one but have too wait.
d67rdave is offline
