I Need Help From the Ford Guys!!!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Truckmaniac, this thread has received 11 replies and been viewed 1185 times.
post #1 of 12 (permalink) Old 04-09-2007, 03:24 PM Thread Starter
Question I Need Help From the Ford Guys!!!!!
I have started several threads on the Dodge Forum with little or no credible replies. I am hoping that someone in this forum has a better understanding of Load Ratings, GVWR and Payload Capacities.
I have a 2008 F350 CrewCab 4x4 shortbed dually due to arrive in about 3 weeks. It is replacing a 2007 3500 MegaCab 4x4 dually (shortbed is the only way this truck is abailable) due to load capacity issues.
My questions are:
Since the MegaCab is built on the same frame, suspension, springs, shocks, axles, brakes and tires as the QuadCab longbox, with the only difference being that the MegaCab has a longer Cab and shortbox, wouldn't it stand to reason that the GVWR would be the same?
They are not!
The MegaCab is only a 10,500# GVWR and the QuadCab has a 12,200# GVWR. The payload capacity of the MegaCab is only 2,800#s (including occupants) while the QuadCab is rated at 4,900#s. The MegaCab axles are rated at 5,300#s for the front and 9,350#s for the rear, the same as the QuadCab that I looked at. Both are riding on E rated 10 ply tires.
I know that all of this is a mute point, since I will be trading the truck soon, but I just have to find an answer.
Truckmaniac is offline
post #2 of 12 (permalink) Old 04-09-2007, 04:55 PM
Mafia member #6
Rutcutter's Avatar
I wouldnt have ever thought that but then again I havent taken a close look at the dodge's anyway.
There are probley several other people in the same position like yourself huh. :shrug:
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #3 of 12 (permalink) Old 04-09-2007, 05:34 PM
Two items:
Sometimes the manufacturers base the GVW rating on what they think the vehicle is going to be used for. The Mega Cab is a more upscale model, so may be considered more a personal use vehicle vs. commercial use.
Also, another consideration in GVW rating besides axles, suspension, and tires is frame strength. Dodge may be using a different frame in the mega cab reducing GVWR.
Just a couple of thoughts.
sacgmc is offline
post #4 of 12 (permalink) Old 04-10-2007, 12:36 AM
Bailey47
Load capacity
The extra weight of the mega cab takes away from the available load carrying capacity. Just like the f350 single rear axle has a higher tow rating than the f359 dually.
bailey47 is offline
post #5 of 12 (permalink) Old 04-10-2007, 12:43 AM
Y_Knot's Avatar
Just a wild guess, but I think the body on the MegaCab would not be as stiff & have more flex than the QuadCab thus making the GVWR less for the MegaCab. As far as I know the frame is the same.
~ Steve
06 Dodge 2500 SLT CTD Quad Cab/SWB 4X4 Thunder Road
Aeroturbine Quadzilla Commander
LORENZ Bilstein Leveling Kit Bilstein 5100's Toyo A/T's
:bolt
Y_Knot is offline
post #6 of 12 (permalink) Old 04-10-2007, 12:45 AM
Y_Knot's Avatar
Duh forgot about the extra weight also !
~ Steve
:bolt
Y_Knot is offline
post #7 of 12 (permalink) Old 04-10-2007, 01:11 AM
Haulin' Azz
BROKER's Avatar
No pin weight in a Mega.
Name:	big-ram (Small).jpg
ID:	9495   Click image for larger version
Name:	ram-interstate (Small).jpg
ID:	9496   Click image for larger version
Name:	rear-interstate (Small).jpg
BROKER is offline
post #8 of 12 (permalink) Old 04-10-2007, 01:21 AM Thread Starter
I'm looking at the 2008 SuperDuty Payload chart and the F350 CrewCab 4x4 SRW Load Capacity is 3,670#s, the F350 CrewCab 4x4 DRW Load Capacity is 4,960#s. GVWR favors the DRW by 1,600#s and Conventional Towing favors the DRW by 2,500#s. 5th wheel towing is the same for both trucks with the 3.73 axle ratio.
I don't follow your logic that the SRW can tow more than the DRw.
post #9 of 12 (permalink) Old 04-10-2007, 01:23 AM Thread Starter
What do you mean by "no Pin weight?
post #10 of 12 (permalink) Old 04-10-2007, 01:32 AM Thread Starter
Thanks for the reply. This is about as close as I have come to a logical answer to my question so far. I had also speculated that since the payload would be concentrated more to the rear of the MegaCab frame due to the long cab/short bed design, that it might hypothetically put more stress in this area than the frame was designed for on the QuadCab Longbed.
