1st oil change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rutcutter, this thread has received 19 replies and been viewed 1787 times.
post #1 of 20 (permalink) Old 04-20-2007, 04:33 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
1st oil change
Well just got threw with my 1st oil change and sure am glad I went ahead and dumped it,had some particals on the oil pan magnent that im glad I got outta there from break-in. Put some good fresh Rottela 15-40 back in and button her up and pulling out for a weekend trip. :Thumbup:
The oil filter is the same as a 6.0L. :Thumbup:
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #2 of 20 (permalink) Old 04-20-2007, 04:50 PM
You did make sure the oil you're using is CJ-4 rated right? (it would be Rotella T Triple Protection NOT regular Rotella)
Copied from HERE
It’s important to resist any temptation to use anything but CJ-4 oil in an EPA 2007-compliant engine, because the higher levels of sulfur, ash and phosphorus in CI-4 PLUS oils may cause problems with the exhaust aftertreatment devices. Using a CI-4 PLUS oil in 2007 vehicles could cause increased plugging of aftertreatment devices, which could lead to reduced fuel efficiency and higher maintenance. All currently licensable categories, including API CF-4, CG-4, CH-4, CI-4, and CI-4 PLUS are not forward compatible to API CJ-4 due to the chemical limits for ash, phosphorous and sulfur defined by API CJ-4.
BONE STOCK
444turbodiesel is offline
post #3 of 20 (permalink) Old 04-20-2007, 06:36 PM
TDG MAFIA MEMBER #85
onebadf150's Avatar
I hope rut did !!! good find 444
onebadf150 is offline
post #4 of 20 (permalink) Old 04-22-2007, 07:16 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Yes I did buy the new rotella,made sure before I poured it in.. Thanks for the reminder though. :Thumbup:
2011 SD F350 6.7L
post #5 of 20 (permalink) Old 04-23-2007, 02:18 AM
I think I'll do that tomorrow 1200 miles :
over29 is offline
post #6 of 20 (permalink) Old 04-23-2007, 02:49 PM
How much was the CJ-4 stuff?
BONE STOCK
post #7 of 20 (permalink) Old 04-23-2007, 03:42 PM
I changed mine this weekend, and found the Wally World had their Rotella on sale for $7.28/gallon. This was in Louisburg, NC. They even had a pallet of it sitting out in the aisle (which is very unusual for Wal-Marts around here).
Duane is offline
post #8 of 20 (permalink) Old 04-23-2007, 07:28 PM
That sounds cheap for CJ-4 oil :shrug: I expected it to be about the same as synthetics.
BONE STOCK
post #9 of 20 (permalink) Old 04-23-2007, 07:51 PM
I paid $9.78
over29 is offline
post #10 of 20 (permalink) Old 04-23-2007, 07:57 PM
I pay 10 something for the new DELO at wal fart
gregrob is offline
