Okay!! Off with the CAT & DPF... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Am124es2, this thread has received 65 replies and been viewed 6295 times.
post #1 of 66 (permalink) Old 05-29-2007, 04:53 PM Thread Starter
Okay... Since the Duramax guys have done it with no real issues, heres the question?
1. I don't want a straight pipe, but a turbo back w/muffler, perferabley 4".
2. Who has or will have this for the 6.4?
3. I would be willing to pay up to 1K.
4. Also a conserative power programmer say 50hp/100lbs. . Say a tow tune and a milage tune... I would like a box set up instead of a programmer due to connect/disconnect. I would pay $ 800 for a quality product.
Has anyone done a straight pipe with a 6.4 not just for a few minutes, but drivin it and testing it.
Also, for some of the guys out there... I don't care about the drivetrain warranty, I will play so I will have to pay. I will have my 08 in the end of July is the plan. I will not do anything to it until I have at least 5,000 on the odo, but can anyone to include vendors give any advise here?:smoke
Blessings,
PS... This is not a rant, but it seems the Dodge guys and the Duramax guys always seem to be ahead of the curve..... as trucks I am a ford guy the other 2 are not an option....:Thumbup:
Am124es2 is offline
post #2 of 66 (permalink) Old 05-29-2007, 07:11 PM
Powered By Ford
FordRacing200's Avatar
If you take off the dpf and muffler, remove all sensors and lay them aside or the truck will go into constant regen mode.
FordRacing200 is offline
post #3 of 66 (permalink) Old 05-29-2007, 08:18 PM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
no one really has a tune as of yet or a turbo back kit either. Bully dog came out with a downloader but hasn't really been tested much yet. Also MBRP has a DPF back exhaust but that isn't a whole lot. wait for a while more will come out
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #4 of 66 (permalink) Old 05-29-2007, 08:24 PM
at least your not gettting your truck until the end of July hopefully some stuff will come out by then
bluestroker is offline
post #5 of 66 (permalink) Old 05-29-2007, 08:30 PM
it shouldnt go into regen mode with an active code for the dpf sensors. unless Ford has stepped on the danger side of things during regen it needs to know how hot the dpf is so as to have it hot enough to clean but not so hot as to melt it.
the biggest issues isnt warrenty but rather legallity they are talking of making all diesel trucks pass an opacity test by 2010 and without a dpf you wont pass and will smoke like mad
Photos of The Beast
DOC
Docluv2577 is offline
post #6 of 66 (permalink) Old 05-29-2007, 09:37 PM Thread Starter
This is why I would like to have a down pipe back exaust. When the event arrises I can put back the stock system without cutting or welding. Elimating the CAT/ DPF my not be "popular" and not looked upon by members favorably, but I am trying to see whats out there so when the time arises I can make a educated decision if doing this is safe and effective... Thanks for the responses...:thanks:
Blessings,
Am124es2 is offline
post #7 of 66 (permalink) Old 05-30-2007, 08:32 PM
what does not kill you ..
I think that the ideal setup will be expensive but work. Here is my idea and the first vendor to use it can PM me for my address to send the check.
A bypass system! Of course the bypass will only be used for OFF ROAD and FARM use to prevent dangerous, environment destroying, green house grass producing, global warming grass fires then you can use the DPF every time you are on road!!!
wftree
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #8 of 66 (permalink) Old 05-30-2007, 09:04 PM
Powered By Ford
Blessings,
the Dmax guys, unhooked the sensors and set them aside, put a strait DP back pipe on it and saved the stock exhaust for dealer visits. if you keep the sensors in it,it will sense a difference in pressure before/aft the DPF and go into constant regen
post #9 of 66 (permalink) Old 05-31-2007, 10:44 PM
That most definitely would not be a good thing if the truck was constantly regenerating itself.
Go Greyhound, and leave your luggage with us. *maybe not intentionally*
Manual 2500 is offline
post #10 of 66 (permalink) Old 06-01-2007, 04:38 AM
I hate all day....
Wildcat's Avatar
or if you dont mind looking at a SES light everyday then you can straight pipe it.
2008 White XLT Sport
Wildcat is offline
